Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Where do I plug in our dvd player to our RCA hd d52w19b?
Pretty crazy that we can't figure this one out.......... any suggestions? thanks
Find red white yellow inputs on back
Posted on Apr 17, 2009
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
I am having no luck connecting a DVD player to this RCA TV/VCR Combo model T25062 even though I am plugging into the correct audio/video outlets? Is it not compatible with a DVD player? Any suggestions? ...
Just to make sure, red/wht is for audio, and the yellow is for video. other then plugging them in you will most likely need to go thru the menu system and find the right location to except the feed from the dvd player.
Mar 08, 2011 | RCA T25062 25 in. Combo
5.1 speakers connected to a dvd player ?
You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
------- If you don`t know how an RCA jack looks like,see this image
Jul 18, 2010 | Logitech X-530 Computer Speakers
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Cannot get my mp3 player to operate on the aux input consistently
I have a 2002 Pontiac Montana and I use a 2 pronged RCA plug at one end with a yellow plug and a white plug, and the other end is one plug to use for the MP3 player. Plug your RCA plugs into the bottom 2 plugs. My RCA plugs on my cord are yellow and black the yellow one is in the middle
plug and the black in the bottom one and I use the AUX input for my MP3 player. I have a SANSA
and a Ipod and they both work fine. I hope this helps. Just a FYI so you don't think your radio is
going whacko after you do get the MP3 player to work the AUX will always come on first and you will have to push the AM/FM button on the dash or the steering wheel to get the radio or DVD back on.
And the DVD player will have to be switched on for the AUX to play the MP3 player.
Have fun...
Mar 28, 2009 | OEM Systems Car Audio & Video
No sound
Is the DVD player connected to the TV via component cables? If so you should have 5 connectors total that will bring picture and audio information to the TV.
Jun 22, 2008 | RCA D52W19 52" Rear Projection Television
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
