Question about Cameras
I have changed both betteries. The field where the info is says help I do not know what to do. A roll of film got stuck halfway thru. I don't know if it was the battery or the camera I have never had trouble with this camera which I bought from ritz Camera store aand which is now defunct. it is a dynax 500si maxxum 400si Thank you!
  • rcampbell84 Apr 22, 2009
    Dear Iversh
    I have gotten the film out and bought new batteries.  I still cannnot get the camera to turn on except for the   help  sign in the window.
    I have put a new roll of film in and it will not advance nor will the camera really go on .  I just has that help sign in the window   I have never had trouble with it before.   I thought the film was wasdefective  but the half roll printed beautifully? after I wrestled it out.  In other words the camera stopped functioning.  The manual says to just take the batteries outand re insert them...Did that but no results.  Please help as I need this.....thanks
    Scholar:
  • 132 Answers
A couple of things to make sure:
-the battery is in the right position
-is the battery showing a full charge in the data panel
-after turning it on, press the P (program auto) button
-is there film in the camera-if so does it show as properly loaded
-it could be the smaller watch quartz battery that needs replacing, it's found in the back of the camera
If you need a manual, here's a link. It tells you the exact battery types you need to use.
http://www.vikenk.com/minolta_manual.htm
If that doesn't help, I would take it for a service to a camera shop as this seems to be a common problem with that model of camera.
I hope that info helped.
Posted on Apr 22, 2009
    President:
  • 1,197 Answers
At the bottomside of the camera you should see a tiny hole, inset a straightened paperclip into it, this will manually release the film.. if its a button type just pressing it wud do... try this if u havent yet...
the roll wud get stuck for two reasons... if u ve wound the film in the opposite direction or
It is possible that the film has broken free from the canister. You may have to try and push it back in the canister by hand
if that doesnt help.....you have to slowly pull the film out by hand. Sounds like there is just a minor jam and thats why the batteries are messing up. Just try to pull everything out because that will be the only way to free it. I see this problem all to often I work with Kodak. Im sure if you take your time and gently pull the film out turn the camera off and back on the cmaera will reset itself and should work just fine.
hope this was helpful thank you good luck with ur camera have a nice day
Posted on Apr 17, 2009
95 Buick ParkAve Power Window Stops HalfWay
you have bad place in scew track replace it. Check to see if something has fell down in track line. roll window down use flashlite to check track.
Sep 10, 2017 | Buick Park Avenue Cars & Trucks
The Film advance lever is stuck, how can I fix this?
This camera is 42 years old. Sounds like a mechanical problem, but I doubt you are going to find any company or individual who knows how to fix it, or can find parts for it, if needed.
Suggest you keep this museum piece as a conversation starter, and invest in a newer model.
If you want to stay with Canon, the Elan 7N and Rebel T2 film cameras are 'only' about 13 years old. I see Elans on eBay starting at $70 (body only).
Jul 04, 2017 | Photography
How do you change the lens?
If you decide to change the lens in the middle of a roll, just do it in the dark, like in a closet or using a "film changing bag"
Here is a link to one such bag
http://www.amazon.com/gp/product/B00023J...
Photographers who needed to load sheet film while in the field, use as well as motion picture, second assistants when loading film into film magazines when in the field, away from the studio Source(s): proFotog
Mar 09, 2011 | Cameras
How do you know if there is film in the camera and if so how do you know how many pictures are left to be taken .
I haven't heard of this camera, but most film cameras have a display somewhere that will show you how many have been taken. They don't usually show how many are left because film rolls can have anywhere from 12-36 pictures on them. If you are unsure about how many the roll of film had, you should assume it was a 24 exposure roll. 24 is the most common. If it doesn't have a number anywhere that you can see, you should take pictures until it stops winding.
If the film has been in the camera for a long time, it's probably better to just unload it and have it developed anyway. Film goes stale after a year or so for most films, so you may not have any good pictures on it anyway.
Hope this helps, if not make a comment with more information and I'll see if I can find a manual online for your camera. I'll need model number and as much more info as you can give.
Thanks
Sep 09, 2009 | Snap Sights SS01 Film Camera
I do not know how to load or unload the 35 mm film.
The cartridge will only go in one way. install and pull film to marked line (should have a few notches in the film strip past gear) close camera and either wind until it stops or if batt powered it will load itself then ready to roll
May 23, 2009 | Photography
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Flashing HI
there is a flexible ribbon cable carrying signals from camera body to the lense assembly. Due to regular use it gets worn out, thus it gets broken and is not able to perform the task for which the camera has given the signal. in your camera also the same flex cable is broken. Get it changed at some good repairer
Oct 26, 2006 | Pentax IQZoom 928 35mm Point and Shoot...
Exposure/ISO compensation
roscaion,
usually around 15 to 20 rolls of 36 exposure film. the iso compensation will either lighten or darken your prints. a good feature if you don't want to change depth of field. ( f-stop )
Aug 07, 2006 | Pentax SF1n 35mm SLR Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
