Question about Canon PowerShot A520 Digital Camera
Software installation problems
While attempting to install the software, the 1st thing I see is an error that my "screen resolution is not sufficient to execute digital camera solution disc" I can't get past this in any way, to load the software. the computer runs windows 2000 and should be robust enough to run the software, it ran the predecessor software (on older Canon digital model) without problems. HELP
  • 2,985 Answers
You do not need software for the computer to read the camera to upload images. The supplied disc with digital cameras is best left in the box let windows do the work If you would like an images editor then downloaf Picasa which is free or invest in a full editing software such as Coral paintshop pro or one of the Serif range
Posted on Sep 17, 2007
Trying to install software for Canon Powershot A640 on a Acer Aspire One Netbook. Receive error message "The screen resolution to execute Digital Camera Solution Disk is not sufficient."
Skip the installing of any software, unless you like the Canon editing or viewing software, if that is on the cd.
Get a card reader for this machine, and skip any drivers whatsoever.
By using a card reader/writer it is not necessary to get any software or drivers on your machine from Canon. The card reader will read as another drive.
Apr 12, 2010 | Canon PowerShot SD1000 Digital Camera
Screen says JVM Error 513 Reset
install Blackberry Desktop on your computer and download the latest Blackberry Phone software from your carriers webite and instal it on your computer. Then connect your phone WITHOUT the battery to your PC and Click on App Loader. Follow directions and install the Software. The Installation WILL FAIL THE 1ST TIME. Thats normal. This time connect the phone WITH the battery and try the same thing again and you will have a brand new phone. except your Data.
Apr 26, 2009 | RIM BlackBerry Pearl 8100
When I install the cd , a error sign comes up
Which software is this? What is the error? If it is screen resolution, here are the steps:
click start/control panel/display/settings and adjust screen resolution to the high side. Once installed, you may adjust the resolution wherever you prefer.
I am not sure if this is your error, but it is a common problem and a quite easy fix.
Hope this helps!
May 27, 2008 | Cameras
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Unable to install the canon Software
Under your control panel in "Display" go to the settings tab and slide the resolution bar to:
Screen resolution: 1024 x 768 pixels or more,
Color quality: Medium (16 bit) or more
That should do it.
Dec 06, 2007 | Canon PowerShot S5 IS Digital Camera
Can't install the solution disk
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Scanner won't scan
Hello, It may be possible that the error msg that you are receiving may be referring to another error. 1st thing I would try is checking the resolution, in some cases if the resolution is too high it may result with numerous issue's if your random access memory (RAM) is not sufficient enough to accommodate the resolution that you attempting to scan with. Try reducing the resolution, also try a different file type, either jpeg or tiff etc..,if all failes check to see if you have the latest driver(s) update for your scanner.
Aug 20, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon PowerShot A520 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
