Question about Sharp AL 1631 Copier
Problem with HP Color Copier 190
My copier just started doing this: When it's finished with the copy, it doesn't advance the paper far enough out so if falls into the tray. It holds onto the end of the paper and begins the new copy on the just finished copy. Or sometimes it will let go of the paper, but it will not fall completely into the tray and the copier will begin copying on the just finished copy. How can I fix this?
Try and make sure exit rollers are touching upper to lower,also cleaned them
Posted on Apr 18, 2009
Cartridges have been aligned but display still says Press enter to align cartridges
HP has a Print and Scan Doctor that can be downloaded to help with problems like yours. Try Googling for it or go to help section at HP.
Apr 03, 2015 | HP Color Copier 190 Copier
Can't find copy menu to take a copy of an address
May i know the printer/ copier model number to assist you better ?
The general rule is, If your printer is a Color printer, then it should have a button/option for COLOR copy.
If it does not have a button/option for Color that means it prints only in black.
Jun 13, 2011 | HEWLETT-PACKARD Hp Ac Adapter Power...
Everytime I hit copy the error says paper, there isn`t any jam, I have tried turning it off, it still says paper jam. Help
There must be some piece of paper or other small material upstructing the path the paper takes and must be thouroghly cleaned to acheive maximum result.
Feb 11, 2010 | HP 190 Copier
Duplex doesn't push the paper high enough to finish the second page so it stops the copier ... paper jam.
try cleaning your duplex feed rollers maybe it would help push tru your second page for complition of your duplex copy
Dec 19, 2009 | Canon NP 6035 Copier
Paper jams - we got copied from mom that passed away - no manual. We don't know what the symbols mean. Trying to score a manual but immediate problem is that paper stops feeding. Error message says there's...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=336&modelid=1936
Unfortunately, I can't direct you where to score a manual either. The jam in this case means that paper did not travel far enough into the copier within the correct amount of time. It is possible to clean the feed roller, (with enough patience) I suggest using IPA (rubbing alcohol). Hope this helps.
Aug 06, 2009 | Canon PC-425 Color Copier
Set up
Setting up the Copier
  1. Open the HP Color Copier product box and remove the User’s Guide. Review the information in the User’s Guide.
  2. Finish unpacking the HP Color Copier. This is best accomplished by resting the box on its side with the unit in the upright position. Pull the unit (foam and all) out of the box. Step 2: Unpacking the HP Color Copier c00222172.jpg
  3. Remove any tape or other packing materials from the unit. Be sure to check inside the machine by opening the cartridge access door.
  4. Verify that you have the power adapter, power cord, print cartridges. If any of these items are missing contact the HP Customer Care Center in your region.
  5. Set the HP Color Copier on a level surface large enough to support it fully.
  6. Load the paper supply tray with paper following the directions in the User's Guide.
  7. Verify that the paper tray is fully inserted into the HP Color Copier and that the rear access door in the back is in the locked position (the copies will be skewed or paper will misfeed if it is not fully locked). Step 7: Verifying that the rear access door is locked c00222173.jpg
  8. Owners of HP Color Copier 280 and 290 models should verify that the ADF (automatic document feeder) cable is securely plugged into the base unit and secured in the holding clip. Step 8: Checking the ADF cable c00222174.jpg
  9. Plug the power cord into the power adapter. Step 9 and 10: Connecting the power c00222175.jpg
  10. Plug the power adapter cable into the unit, then plug the power cord into a power source, preferably a wall outlet.
  11. Press the Power button on the right side of the front panel to power it up.
  12. Open the front panel to access the print carriage. Raise both cartridge latches after the print carriage comes to the center. Step 12: Opening the front panel and raising the cartridge latches c00222176.jpgc00222177.jpg
  13. Remove both print cartridges from their containers being careful to only touch the black plastic portions. CAUTION: Do not touch or remove the gold colored contacts.
  14. Carefully remove the tape that covers the print nozzles on the bottom end of the print cartridge. Step 14: Removing the protective tape c00222178.jpg
  15. One at a time, insert the cartridges into the print carriage and latch them into place. Step 15: Inserting the print cartridges c00222179.jpgc00222180.jpg
  16. Close the access door.
  17. Observe the display and confirm and/or set the language by entering the language code. The following steps will change the language on the front panel:
    1. Press MENU.
    2. Press 3, then 5.
    3. Scroll to the correct language and press ENTER.
  18. The display should read “Press ENTER to Align Cartridge”. Press the ENTER button on the front panel to accomplish this task. The self-alignment process will begin and an alignment page will be printed. Verify that each task has a green check mark beside it. Step 18: Ink cartridge alignment page c00222181.jpg
May 29, 2009 | Sharp Office Equipment & Supplies
HP 190 Cartridge cleaning not lasting
You should apply to service. The Fault is caused by wear-out rakel knife. This device which clean the photo a drum.
Mar 25, 2009 | HP 190 Copier
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Staple problem
pull about 1 inch of staples out of the cartridge, tear off the 1 inch so new staples are flush with plastic cartridge. Reinstall and make 10 stapled sets. By the time it tries to staple set number 3 or 4 you should start to see the staples working. It could take as many as 8 or 9 sets for the staples to advance far enough. Once it staples you are all set/
Mar 19, 2008 | Sharp AR-407 Copier
Sharp AL 1631 Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
