When i connect external monitor to my ACER ASPIRE ATOM1 NOTEBOOK, the system automatically go to battery,,i mean even if AC is plugged it runs on battery...what could be the reason & how to solve it???
    Problem Solver:
  • 12 Answers
Go to Control Panel and select Power Options. Set up a custom power plan.
Also, remove your battery when using AC to prolong its life. Overcharging can deplete the life of the battery over time.
Posted on Jul 21, 2009
My acer laptop screen is black
Borrow an external monitor from someone. Plug it into your Acer. Power on both. Your laptop should automatically detect the external monitor.
Sep 14, 2010 | Acer Aspire 5100 Notebook
Hello. I want to ask. I have a Acer Aspire 9300 and I have a problem with it. When I try to turn it on it only ignites the green light and the computer does nothing and does not make any sound. What could...
First, make sure it is fully charged and plugged in.
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. Check the
following:
If you are using on the battery, it may be low and unable to power
the computer. Connect the AC adapter to recharge the battery pack.
Make sure that the AC adapter is properly plugged into the computer
and to the power outlet.
If it is lit, check the following:
Is a non-bootable (non-system) disk in the external USB floppy drive?
Remove or replace it with a system disk and press <Ctrl> + <Alt> +
<Del> to restart the system.
Nothing appears on the screen.
The computer's power management system automatically blanks the screen to
save power. Press any key to turn the display back on.
If pressing a key does not turn the display back on, three things might be
the cause:
The brightness level might be too low. Press <Fn> + <→> (increase) to
adjust the brightness level.
The display device might be set to an external monitor. Press the display
toggle hotkey <Fn> + <F5> to toggle the display back to the computer.
If the Sleep indicator is lit, the computer is in Sleep mode. Press and release
the power button to resume.
Aug 28, 2010 | Acer Aspire 9300 Notebook
My acer aspire 5610z series does not trun on even with the power cored followed rebooting trouble shooting nothing wrked i think it made it worse what do i do
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
I have acer 3050 is switch on but no display
Hi! Try to check if there is a hotkey to turn on/off lcd display. If none, try to power drain the machine by unplugging ac adapter and removing the battery.Press and hold the power button for 10 secs and then after that put the battery back and plug in ac adapter.Press power button and then check if you will see anything on the screen,if still the same then try to connect the laptop to a external monitor and then press FN+F5 to switch display to external monitor, if you see something on the ext monitor it means you are dealing with a faulty lcd on your laptop...Hope this helps...
May 20, 2010 | Acer Aspire 3050-1733 Notebook
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Aug 02, 2009 | Acer Aspire 7720 Notebook
Need help for Acer Aspire ONE MODEL # ZG5 screen does not work?My Acer Aspire ONE MODEL # ZG5 notebook is show that the power is on, but the screen is black. I can hear the computer running, but there is...
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Mar 26, 2009 | Acer Aspire One PC Notebook
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Keyboard/touchpad freezes when the battery is plugged!!
I SOLVE THIS ISSUE 100% WORKING
THE MAIN PROBLEM IS ON THE CONTACT BETWEEN THE BATTERY WIRES AND LAPTOP
IF YOU MOVE THE BATTERY IT WILL WORK SO SURE THE PROBLEM WITH THE LINK BETWEEN THE BATTERY AND THE LAPTOP
SOLUTION : TO MOVE THE IRON OUT OF THE LAPTOP TO THE RIGHT TILT THEM TO RIGHT SIDE A LITTLE BECAUSE THE BATTERY WIRES IS TO THE RIGHT SIDE (WATCH THEM) NOT IN THE MIDDLE AND AFTER THAT PUT A STICK ON THE BATTERY TIGHTED IN ITS PLACE SO IT WILL NOT MOVE ITS NOT FREEZING NOW THANKS
Dec 21, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
