My At&T Modem will not work via my linksys router
I just installed my linksys router to my new At&T dsl router ....but it would not work ....what am i doing wrong. When i run the ethernet str. to my computer it works just fine. has anyone had this problem and a solution
  • Leng Yang May 11, 2010
    Your set up should be as follows:
    From the phone jack on the wall, telephone wire goes to your AT&T modem
    From the Modem, ethernet cable should go to your Linksys router...
    then from the router, it will distribute out to your computers via ethernet cable.
    Is that how your set up is?
  • 53 Answers
Turn the power off on your modem, router and pc. Then turn on your modem and wait for connection, then turn on your router, then your pc. The ip addresses will all reset and should allow a connection.
Posted on Jul 28, 2009
Dsl modem = to 3 linksys wrt110 routers for wi-fi ?
What you are trying to do is a rather big job. Hire a company to connect the equipment properly. The headaches you save will be your own. If you install it, you will have to fix it everytime it goes out if you contract someone to install it and you buy a support contract when they install it, THEY get to come fix it and the headache is theirs, not yours. And NEVER install that type of router in an attic, they will overheat and fail very quickly.
Oct 19, 2012 | Linksys RangePlus Wireless Router WRT110 -...
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
You should get output somewhat like: Default Gateway .... 192.168.123.456
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I just installed dsl and want to use it with my existing router and the router doesnt want to work with the dsl ...help what do i do ???
First, make sure the dsl is working by connecting it to your computer directly.
Next, turn the router off, turn the dsl modem off, connect the dsl modem to the router. Start the dsl modem first, then start the router, then start your computer and try to connect.
Nov 07, 2009 | Linksys Wireless-G WRT54G Router
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
