Question about Intel D945PSN Motherboard
Is Seagate Barracuda 750 GB hard drive compatible?
The computer stutters at times. Quite a bit when I am using itunes, and also when I run software, like Office, and play solitaire. Is this hard drive compatible with this motherboard, the D945PSN?
  • Leng Yang May 11, 2010
    Please explain "stutters".
    Do you mean its an audible sound that you hear or that when you access it, it is delayed in getting you the information?
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
you will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try ebuyer.com
Mar 31, 2015 | Seagate Barracuda 7200.10 (ST3750640AS)...
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Require replacement power/data pcb for a seagate barracuda 7200.11 1000Gbytes part number on PCB is 2HBAHNRQ
Contact your local computer store, a computer technician/data recovery technician may have just that circuit for you to use and transfer your data onto a new hard drive.
You may also try to contact Seagate in this regard, they offer 3 year warranty on all Barracuda hard drives.
Take care!
damnor01
May 28, 2011 | Seagate Barracuda 7200.11 - hard drive -...
How to transfer data from seagate barracuda 7200.7 ST380011A 80 GB hard drive to another hard drive after crash?
You need a usb cable to harddisk. than a computer running linux. connect hd by usb to linux and copy.
Jan 13, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Lags and says has bad sector after 14 months
Good day sir/maam, hi, 14 months is too short for a hard disk operating span, what we do is run the diskmanager software that comes with the seagate hard disk, on the diskmanager menu, run the low level format which usually removes the bad sectored space out of the way, and mark it as not usable. then may I suggest you partition your hard drive to 2, one for windows and the the other for data. call your computer dealer if they have in house techs for service, or get the copy of disk manager for your seagate. Hope this helps, thanks
Nov 04, 2009 | Seagate 750GB BARRACUDA SATA 7200 RPM 32MB...
How do I set my 7200 Seagate drive as slave
Look at the diagram on the drive, you will need a jumper
MA = Master
SL = Slave
CS = Cable Select
If it's EIDE use the center connector on the cable
Oct 25, 2009 | Seagate Barracuda 7200.10 750 GB SATA Hard...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Intel D945PSN Motherboard Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
