Question about Whirlpool LER5636P Electric Dryer
No heat in or coming out of the dryer Whirlpool LE6800XTWO
I have checked the dryers exaust vent and there is air flow . I also reset the main breaker to make sure that the 240 V receptical is actually putting out 240 volts . What else could the problem be ? I think that it is the heating element in the dryer has gone bad .
  • 686 Answers
FIRST CHECK YOUR THERMAL FUSE FOR CONTINUITY IF NONE REPLACE IT AND REPOST
Posted on Apr 17, 2009
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
The dryer isn't providing any heat
Try Resetting your Breaker, even if the dryer is tumbling. Sometimes one breaker on a double pole trips. Also check the vent to be sure there is air flow. A clogged vent system will leave clothes wet.
Feb 27, 2011 | Whirlpool LER7646E Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
No heat in dryer
Air flow is the air coming from the fan via a hose vented outside...the element can be checked by a multimeter should read about 32 ohms if its ok no readings means its open circuit..could also be thermostat..1st see if has thermal cut off ' back of machine to reset......
Apr 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gas dryer quit heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Electric whirlpool dryer turns & heats but does not dry
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the section that discusses proper dryer ventilation. The fact that you don't see any lint collection in the lint trap could be a symptom of a dryer that is clogged, or an exhaust vent clog. An easy way of determing whether or not the problem is with the dryer, or the ventilation, is to remove the exhaust vent line from the back of the dryer and attempt to dry a load as normal. The air flow coming from the back of the dryer should be forceful and warm (about 140 degrees). If this is the case, the problem is NOT the dryer and may be attributed to something in the ventilation ducting from where it leaves your dryer to where it exits your home. An inspection of the vent ducting should be done to confirm it is clear and free of clogs or kinks.
If the air flow is weak, then you have a clog INSIDE your dryer. An inspection of the dryer blower fan housing should be done to ensure the fan is turning unobstructed and there are no clogs. If the air is cool, you probably have a failed component in the heating circuits.
Read through the link I provided and let me know if you have any questions. I hope this helps you.
Jun 22, 2009 | Whirlpool LER4634J Electric Dryer
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool ultra capacity dryer and a code keeps flashing when i;m drying it says AF
The AF indicates an insufficient air flow.You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
Dec 14, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool LER5636P Electric Dryer Logo
252 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
