Question about Panasonic Office Equipment & Supplies
Dark copies in normal mode.
When I select copies in normal mode they are printed dark,but in light mode the copies are printed perfect. Someone told me that I may adjust the voltages but I don't know how to do it or what it's the card that manage this.
  • NDTechGroup Corp.
    NDTechGroup Corp. Apr 17, 2009
    ...by the way, this model is FP-7713/7715
Cleaning the optics and corona wires will clean up your image quality. It's just dust build up on the mirrors and lens.
Posted on Apr 17, 2009
Hi . i have a ep1054 and print veri light , i want change to dark
Are you printing in "draft" mode? That is always light. Try "normal" or "quality". Also make sure you have selected the correct paper type. "Plain paper" is what most paper is. Photo paper is quite different, and photo paper setting will not work correctly on plain paper.
May 09, 2015 | Office Equipment & Supplies
If copy quality is very dark then what to do for making it normal
The dark quality is definitely linked to a light intensity problem. If the scanner lamp is operating properly then check for any reflective surfaces near the scanning lamp and clean those. It only takes a light film of dust to make copies dark. Be careful around the lamp, it is delicate.
Jan 26, 2015 | Canon 2234B007 - Faxphone, L90 Laser,...
I have a MP280 printer/scanner/copier that prints my photos out to dark, when it is on the computer it is pefect colour
Open the printer driver setup window
Select the manual color adjustment (or if already in manual and it had initially been printing fine, you may opt to select Auto)
On the Main tab, select Manual for Color/Intensity, and click Set....
The Manual Color Adjustment dialog box opens.
Specify the brightness
Select Light, Normal, or Dark for Brightness, and click OK.
The current settings are displayed in the settings preview on the left side of the printer driver.
Complete the setup
Click OK on the Main tab.
When you execute print, the data is printed at the specified brightness.
May 16, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
I need to lighten print on my richo2210L fax machine
To adjust the contrast, Press Darkness. Each time you press the button, the LED labeled with the selected mode turns on. You can choose from the following darkness modes:
1>Lighten: works well with dark print.
2>Normal: works well with standard typed or printed documents.
3>Darken: works well with light print or faint pencil markings.
Dec 07, 2011 | Office Equipment & Supplies
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
My ink prints too dark is there an adjustment on the printer
yes.there is a adjust ment.go to printer properties and there printing preferences and there adjust the print quality to normal which is set on beat mode so the prints are comming extra dark.
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
118 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
