On my cabrio gas dryer the pilot lights up then goes out in about 1 min
Must be a bad sensor. These new fangled models use electronics to sense the heat. In the place of a control klixon, they use a thermistor. The thermistor changes in resistance with changes in air temps. The fancy shocktronics upstairs monitors the thermistor for resistance. if it cannot read any resistance it shuts down. Measure the thermistor for resistance if ya cannot get a reading or it is out of spec then replace it. Another thing is the small belt on some of these falls off and the blower stops working. The dryer quickly overheats and shuts down. You can access a service manual by going to appliancejunkgoogledrive and accessing dryer service manual section.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
SOURCE: Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
SOURCE: is there a pilot light on amana gas dryer model LG4309W
There is no standing pilot light. The gas is ignited by a hot surface device that is electrically controlled. Trace the exhaust venting to locate the burner area.
SOURCE: Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
