Question about Dell OptiPlex GX620n PC Desktop
Case Cooling fan runs at high speed
I've had this PC for about three years and the cooling fan hardly ever ran. Then a few months ago when ever you turn on the machine the fan would come on at full speed. I opened the case and using canned air I blew out the dust from the CPU heat sink and the power supply. This did help and now the fan runs about half speed. If I touch the heat sink it isn't even slightly warm. Any help would be appreciated, since I'm going deaf !
Thanks in advance,
Vince
    Scholar:
  • 39 Answers
A few possible solutions.
You said that you got some canned air to blew it out... what I normally like to do is simply use a vacuum and **** up as much dust as possible (besides who wants dust in your face?). Once that is done, I would advise that you take off the fan from the CPU cooler itself and get in there with either the canned air or vacuum... simply because with the fan still attached, there is possibly still a layer to caked dust under the fan and on top of the heat sink.
If it is any of the other case fans, I would either get in there and vacuum them out really good or simply replace them. My computer use to sound like a jet engine after 2 years but when I replaced my fans (with cool blue LED ones) it was significantly (can't stress enough) quieter. Most fans are of course using ball bearings, so if you can imagine the bearings getting a good layer of dust in them as well...
Posted on Apr 17, 2009
When i start my 2008 Cadillac sts i get a notification that engine hot A./C off. Even though it is the first time i stated it today
ENGINE HOT - AC OFF
Cooling System Description and Operation
you must have a cooling system problem of some sort !
Do the cooling fans come on when A/C is switched on ? Fan's should come on ! Does your vehicle have two or three cooling fan's ?
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Cooling
Having a qualified professional technician check it out would be your best bet ! Hooking up a factory or professional type scanner an check data input's an DTC'S - diagnostic trouble codes .
Diagnostic Starting Point - Engine Cooling
Begin the system diagnosis with the diagnostic system check. Refer to Diagnostic System Check - Vehicle . The Diagnostic System Check - Vehicle will provide the following information:
• The identification of the control modules which command the system
• The ability of the control modules to communicate through the serial data circuits
• The identification of any stored DTCs and their status
The use of the Diagnostic System Check - Vehicle will identify the correct procedure for diagnosing the system and where the procedure is located.
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active
DTC P2600: Auxiliary Coolant Pump Relay Control Circuit
DTC P2601: Auxiliary Coolant Pump Performance
DTC P2602: Auxiliary Coolant Pump Relay Control Circuit Low Voltage
DTC P2603: Auxiliary Coolant Pump Relay Control Circuit High Voltage
Dec 10, 2017 | Cadillac Cars & Trucks
I have a 2006 buick lucerne 3.8 v6 cxl.my coolinf fans dont come on .i need to know how to change the relay and the fuse.
Your vehicle cooling fan's are controlled by three relay's , couple of fuse's an the PCM - engine computer . The engine coolant temp. sensor is a input to the PCM , when engine temp get's to 212 the PCM will turn on the cooling fans in low speed . Checking to see what the actual temp is with a scan tool an a infrared thermometer at the thermostat housing ,an looking up the specification's in a service repair manual is how to diagnose . Not guessing an replacing parts . Plus learning how the cooling fan's work .
Relay Driven Dual Cooling Fan Diagnostics Reading factory service info as to how they work also would be a good idea .
Dec 10, 2017 | Buick Cars & Trucks
Where is the cooling fan switch located on my 2005 malibu 3.5liter v6
Cooling fan switch ? The cooling fans (2) on that motor are controlled by three relays . A coolant temp. sensor gives temp info to the PCM - engine computer .
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan S/P relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The PCM commands Low Speed Fans on under the following conditions:
• Engine coolant temperature exceeds approximately 106°C (223°F).
• When A/C is requested and the ambient temperature is more than 50°C (122°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off if the engine coolant temperature at key-off is more than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans on under the following conditions:
• Engine coolant temperature reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set .
Watch this video ,it shows how it works !
Nov 27, 2016 | 2005 Chevrolet Malibu
Need a wiring diagram of the 2 wires from the temp sending unit that controls the temp gauge and cooling fans on a 99 grand am gt. Need to see where they go They disappear behind the engine
The PCM regulates voltage to the coolant fan relays, which operate the fans. Refer to Engine Controls.
Engine Cooling Fan Description - Electric
The electric cooling fans are used to lower the temperature of the engine coolant flowing through the radiator. They are also used to cool the refrigerant (R-134a) flowing through the A/C condenser.
Operation
The electric cooling fan operates when the engine cooling temperature exceeds a certain value. The cooling fan on this engine is controlled by the PCM. The cooling fan has one speed. The PCM turns the cooling fan ON by grounding the coil of the cooling fan relay when certain conditions are met. When the A/C is requested, the cooling fan will also be turned ON.
Power for the cooling fan motors are supplied through Cool Fan #1 and Cool Fan #2 relays. The cooling fan relays are energized when current flows from the fuses in the Cell 23: Cooling Fan Controls , and through the relay coils to ground through the PCM. The Low Speed fans control circuit is grounded for low speed fans operation. During low speed fans operation, both fans run at a slow speed. The High Speed fans control circuit is grounded for high speed operation. During high speed fans operation, both fans run at high speed.
Important: When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. It is important to perform Powertrain On Board Diagnostic (OBD) System Check prior to diagnosing the engine cooling fans.
If a problem that involves the low speed cooling fan relay control circuit exists, DTC P0480 should set. If the problem affects the high speed cooling fan relay control circuit, DTC P0481 should set. A problem with the ECT sensor should set DTC P0117, P0118, P1114, or P1115. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Cooling Fan Diagnosis tables. The Cooling Fan Diagnosis tables should be used to diagnose the PCM controlled cooling fans only, if a DTC has not set.
The engine coolant temperature (ECT) sensor (3) is a thermistor, a resistor which changes value based on temperature, mounted in the engine coolant stream. Low coolant temperature produces a high resistance (100,000 ohms at -40°C) (-40°F), while high temperature causes low resistance (70 ohms at 130°C) (266°F).
The PCM supplies a 5 volt signal to the ECT sensor through a resistor in the PCM and monitors the terminal voltage. Since this forms a series circuit to ground through the ECT sensor, high sensor resistance (low temperature) will result in high PCM terminal voltage. When the resistance of the ECT sensor is low (high temperature), the terminal voltage will be drawn lower. This terminal voltage indicates engine coolant temperature to the PCM.
A hard fault in the ECT sensor circuit should set either a DTC P0117 or P0118. Remember, these DTCs indicate a malfunction in the engine coolant temperature circuit, so proper use of the DTC table may lead to either repairing a wiring problem or replacing the sensor, to properly repair a problem.
The engine coolant sensor is an input to the PCM , Two wire's both go to the PCM .An the PCM turns on the cooling fans !
DTC P0480 Cooling Fan Relay 1 Control Circuit
DTC P0481Cooling Fan Relay 2 Control Circuit
The Body Control Module (BCM) request the cooling fans. The BCM sends a Class 2 message to the PCM in order to enable the fans based on various inputs. Thebattery voltage travels to all three cooling fan relay coils. The PCM enables cooling fan relay #1 by providing the ground path. The PCM enables cooling fan relays #2 and mode control together by providing a ground path. The left and right cooling fans are connected in series. This will enable both fans on low speed when the fan #1 relay is energized. When all three fan relays are energized, both fans will operate at high speed. The high speed is possible because the fan relays are wired in a parallel circuit. When the PCM detects that certain DTCs are set, the PCM will enable the cooling fans.
The PCM will enable the engine cooling fans when certain Diagnostic Trouble Codes are set.
Important: A short to ground will cause an open fuse(s). Before performing this diagnostic procedure, inspect the fuse(s) for an open.
Did you perform the Instrument Cluster System Check?
Go to Step 2
Go to Instrument Cluster System Check
Turn the ignition switch to the ON position.
With the scan tool select Instrument Panel Cluster, Special Functions, Instrument Panel Cluster (IPC) gauges.
Perform the Coolant Gauge Sweep Test.
Does the coolant temperature gauge complete a full sweep when commanded?
Go to Powertrain On Board Diagnostic (OBD) System Check in Engine Controls
Go to Step 3
Replace the instrument cluster. Refer to Instrument Cluster Replacement .
Did you complete the repair?
Your best bet would be to take your vehicle to a qualified repair shop that knows how the system works . An has the tools to diagnose the problem .
Nov 13, 2016 | 1999 Pontiac Grand Am GT
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Blower does not activate when a/c mode but works fine without a/c
on your fan motor. red is low speed ,blue is med speed, black is high, red for heating . blue works good for cooling. black is high speed. re look where the forth speed was hooked up. put blue there.
Apr 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
My computer fan speeds up whenever I'm on the
Nothing ... probably ... your fan speeds up when the processor temp goes up ... the more you are doing, the more cooling you need. The processor is calling for more cooling so the fan runs faster.
If this is a concern for you, you may wish to consider adding another fan to your case. In any event, make sure your power supply fan is clean. Use a vacuum or canned air to clean.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
I have a Protechnic MAGIC CPU Fan, MGT7012UR-015 , 12v, 0.58A in my Acer PC. The manufacture date is 2007/8/28. It has started making a whining sound so I need a replacement. True to form, the warranty...
its a standard 80mm fan. You dont need one by that company as its a interchangeable part.
any of these will work
http://www.frozencpu.com/cat/l3/g36/c15/s58/gallery/p1/Fans-12_Volt_Fans-80mm_x_25mm_Fans-Page1.html
any of these will too
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=+40000573&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=-1&description=80+mm+fan&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Feb 19, 2010 | Magic Protechnic 80mm Sleeve Bearing Case...
Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Nov 10, 2009 | Sony VAIO VGN-N130G/W Notebook
Dell OptiPlex GX620n PC Desktop Logo
321 people viewed this question
Alun Cox
