Question about Jabra BT125 Headset
How to pair the jabra BT125 headset with personal computer to here songs without using head phones
    Genius:
  • 1,689 Answers
Hi vrajasekar20, thank you for using fixya.
to pair your jabra to a PC for headset use, you have to install the jabra PC Suite first and use it as your default sound input / output device.
The PDF file below will give you a step by step instruction on how to have it installed and working.
http://www.jabra.com/sites/Jabra/GNimages/Products/Adapter/A330/A330_FAQ_EM_EN_2838.pdf
Should you need more info on this matter,please do not hesitate to let us know.
regards,
voodoo
Posted on Apr 17, 2009
Cannot connect bluetooth headset with phone
read the directions from Samsung about pairing Bluetooth devices
Feb 19, 2010 | Jabra BT125 Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
What is my pin?
default should be 0000
methinks
try it
Jul 22, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
Apr 15, 2009 | Jabra BT125 Headset
Can't pair Jabra BT125 with O2mini
check the bluetooth is in visible mode or not
Jan 07, 2009 | Jabra BT125 Headset
Jabra bt125 won't pair to motorola razor v3
I had the same problem and found the user: Splut wrote in another problem the following solution: If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. I tried that to connect my Blackberry phone to my Jabra BT2010 headset and it worked!! I had tried everything prior without success. I hope this works for you. DIVA08
Dec 15, 2008 | Jabra BT125 Headset
I need to reprogram my Jabra BT125 to a new phone, but don't have the instuctions to do that.
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
Jul 12, 2008 | Cell Phones
Jabra BT125 Headset Logo
1,211 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
romy sibug
romy sibug
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
