Question about Linksys Wireless-G Broadband Router
RESET PASSWORD I've been trying to access my router's GUI. the window that prompts me to enter username and password pops up but when I type in the default password ( admin) i still cannot get through. I was wondring if it's possible to reset the password to its default ( admin )? I may have changed the default already but totally forgot if I ever did.
  • zLORDz Sep 17, 2007
    Thanx! forgot to tip in that I already did try the reset button several times from 30secs even up to 3mins. I still can't get into the GUI.
  • jit1234567 Mar 01, 2008
    i am not been able to access linksys configure, whenever i tried to access it beetel access
Press the rest botten in the back for 25 sec. This should set it back. You can also call the company for free and they can tell you if this does not work.
Posted on Sep 16, 2007
  • Jc Caro Jun 26, 2013
    i've tried that and it will not reset the username and password... i want to access the GUI so i can change the SSID and the WEP key
SOURCE:
Where do I get the code
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings.
Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all.
As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else.
You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed.
Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
This can be done by opening your internet browser (i.e. Internet Explorer, Firefox, Safari, Opera, etc.) and typing in the address bar 192.168.1.1.
Once you hit enter, an authentication panel would pop-up requiring you to enter a username and password.
Note: If entering 192.168.1.1 does not bring up anything, your default gateway may not be that.
For Windows, just go to Run command (Windows Start button, then click Run), and then type "CMD".
A DOS prompt would pop-out and you would just need to type, "IPCONFIG". Look for the words "Default Gateway", the numbers beside it are the ones you need to enter into your browser
Usually, its 192.168.1.1 or 192.168.0.1 so most likely you wouldn't have to do that.
Another Note: The usual username and password is "admin" (without the quotes).
For some routers, the username is admin, and the password is blank.
Jan 09, 2014 | Computers & Internet
How can i recover my wifi password
You must log into the router using the routers internal ip address. Open your default browser (eg: internet explorer or google chrome) and enter 192.168.1.1 into the address bar, press enter. You will be prompted to provide a username and password, use admin for both, press enter and the Linksys GUI will pop up. You will need to navigate to the wireless settings tab and either write down your current password or change it. Make certain that you save all current settings before exiting the GUI.
Sep 29, 2011 | Linksys Wireless-G WRT54G Router
How to change password
Wireless password or admin access password?
I assume the wireless password.
login to the router here http://192.168.1.1
use you access password or the default password "admin" no username is requird.
click on the wireless tab then the security sub tab depending on your security type you will have different options. best to set it to WPA or WPA2 and then enter a password
Aug 29, 2011 | Linksys Wireless-G WRT54G Router
Hello i have reset my router and now cannot reconnect to The internet i have no idea what the username/ passwords ate
From my understanding you have lost or forgotten your wireless password and or router login settings. You are able to reset this to factory default by locating the reset pin in the back. Once this is located you are going to want to grab a pin, paper clip, something of this sort. You will want to insert this object into the reset hole for 30 seconds and release. Your router should be back to default. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password. With the defualt settings your password may be blanked out. You are able to setup your wireless network name and password again. I hope this has helped
Jul 29, 2011 | Linksys Wireless-G WRT54GS Router...
I want to have my router password protected
To enable password on the wireless network of the router please follow the below steps:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Hope the above steps helps you to resolve the issue.
Regards
Anand
Apr 21, 2011 | NetGear WNR2000 Wireless Router
Want to remove code to modem
Press the reset button in the back of the router for 30 seconds with a sharp object (an unbent clip for instance) to reset the modem to factory settings. This will remove the router password and any protection settings. For detailed instructions with images, check this FAQ: Resetting the Linksys Router to Factory Default to remove .
Next, open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter.
A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password. enter the new settings.
Check this FAQ: Accessing the Router's Web-Based Setup Page and the other mentioned at the itsend.
You can get more FAQS and support for your router here: http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
Sep 30, 2010 | Linksys Wireless-G WRT54G Router
How to set up security to the router DI 524,
To open the gui of the router open internet explorer and in the addres bar type 192.168.0.1 and hit enter. You would be prompted for a username and password. The default username as admin and password as <blank> for the unit.
Try this, in case you are not able to access the UI of the unit with the username and password try pressing the reset button on the unit for 20 seconds. This would restore factory defaults on the device, once done try to access the ui of the device as explained above
Jul 07, 2010 | D-Link AirPlus DI-524 Wireless Router
DELL E6400 Connect to wireless Modem problem
I have the EXACT same problem on the same computer.
I'm not an expert so I searched online but didn't really find a lot of responses to this Dell issue. One suggestion was to turn off Intel PROset and let Windows manage the wireless connection.
That worked for me.
When in the Intel PROset menu, click on Advanced, then click on "Let windows manage your wireless set-up."
Alternatively, you can toggle between the two software by pressing F10.
This solution worked for me.
Jun 08, 2010 | Dell Latitude E6400 Laptop
I cannot gt into the router
Hard reset properly for 30 secs. & Powercycle and try again.
Mar 17, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
If I reset my router, do I need the CD to reconfigure or change the password
You don't actually need the CD to reconfigure your router or change the password or anything related to your router. So long as the router is connected to your computer via ethernet cable you can access the browser configuration page of your router.
1. connect your router to your computer via ethernet cable
2. If you are using Windows XP
- click start
- click run
- type cmd
- in the black screen type ipconfig and press enter
- look for the default gateway (example 192.168.1.1)
- Open Internet explorer
- type in the address bar: http://the default gateway (example http://192.168.1.1) then press enter and it'll ask you for the password
- usually the username is blank and the password is admin or the username is admin and the password is pass or password
If you are using Windows Vista / Windows 7
- Click the pearl button
- Click on start search at the bottom of the pop-up window
- type cmd (don't press enter yet)
- right click the black icon on the top of the window after typing cmd
- click on the run as administrator
- click on continue if there's a prompt
After successful accessing the configuration page you can now configure your router freely.
Jan 11, 2010 | Gateway Wireless-B Router (wbr-100)
Linksys Wireless-G Broadband Router Logo
1,189 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
