Question about RCA Televison & Video
Rca big screen P61937
My t.v was working fine one day till it started curving to where you can't see the channels and some of the wording.. can someone please tell me what could be wrong with it?
    Genius:
  • 1,139 Answers
Hello crystallb200,
Your Convergence Amplifier ICs have malfunctioned, and have to be replaced.
Here is a brief description on how you can change these out yourself, however if you do not have a background in electronics I suggest that you have a qualified TV technician work on solving this for you.
Remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Apr 17, 2009
I have a RCA Gemstar P61937 with no sound.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 575 posts to different brand TVs.
Aug 13, 2012 | RCA 27V530T 27" TV
RCA 61 inches year 2003 Model # P61937 Need ballast board part # 12481311581202 Whats the price of the part and where can I find it I.m from Puerto rRco
Tries these websites like Tvrepairworld.com,Tvrepairkits.com and Ebay.com to search and buy.Price are vary at each sites.
May 16, 2010 | RCA P61927 61" Rear Projection Television
RCA HDTV D52W23- words in 3D - picture at top and bottom black
are you still having this prob? i am having a similar prob with the same brand of tv. if you had yours fixed please help me with mine.
i think it is the convergence ic. i need three ic but the distributer will nit sell no less than ten of them. if you or anyone need any of those ic i could let you some for the same unit price i bought them. posted 09/02/2009
Jun 28, 2009 | RCA D52W23 52" HDTV CRT TV
Projection on the screen is too large so the pic is cut off
using the right or left arrows should change your screen sizes 16.9 4.3 and so on
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Screen turns all pink
Good Day pittisit1976;
Sounds like you have a bad M-301 assembly. You could call a service center that is Authorized or change channels a lot.
Good Luck, big IRISH.... Make sure to get an estimate...
Jun 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
369 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
