Question about Aurora Electronics Office Equipment & Supplies
I just bought my shredder 3 weeks ago and apparently a paper jam caused my shredder to stop working, when I dislodged the jam, my autoshredder will not start. I think the auto switch is not being triggered. my shredder is the Aurora AS800CD
  • 537 Answers
Did you open up the shredder or remove it from the basket? Look and see if the switch is in the right place and is not being blocked.
If you didn't mess with the switch and just cleared the jam, then take it back to where you bought it for a replacement
Posted on Apr 17, 2009
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
I jammed it with too much paper
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
My paper shredder has stopped working. There is nothing jamming it - what should I do?
I had this same problem on one machine i repaired and when I took off ththe top cover it had a bad gear where it was split and it would run fine backwards, but not forward. the gear is available online. it was also
clogged with paper, which must have caused a lot of torque on the gear. they are plastic, so they will break instead of really messing something up. good luck
Jul 24, 2012 | Fellowes P-48C Cross-Cut Paper Shredder
Runs in reverse and forward ,when insert paper blades won't let paper in
unplug it and then use compressed air (duster can used for pc's) spray this into unit and into teeth area. This should dislodge any unseen material.. (TIP - don't put any staples or clips in the shredder) even thou it says you can - this can cause a jam as well as not recognize paper. I recommend you get Shredder OIL to use 1 a month to keep your shedder in good condition
Jan 01, 2012 | Royal VF700 Cross-Cut Shredder
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
    Instructions
    Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
    Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
    Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
    Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
    Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
    Good Luck!
    Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
    Fellowes Powershred PS 60CC stopped working
    I own a Fellowes PS 60 shredder.
    Here is a link to the manual for a Fellowes PS60 Shredder.
    Maybe it will help you in resolving some of your problems.
    https://app.box.com/s/q3r8jlatlfskvgyh5ne6
    Fellowes Shredder PS60
    Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
    All lights turn on as needed and has power but won't grab paper to shred
    suspect paper jam try using reverse button the dislodge paper.
    suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
    suspect a panel or bin is not correctly seated causing the shredder to not start.
    Nov 13, 2009 | Fellowes Powershred 320C Shredder
    Infoguard SX100M Shredder - motor on but not feeding paper
    I have a SX100M and it runs in reverse but not in forward. I went to used it one day and it didn't work. I don't see anything jammed in it. I bought it 3 years ago but it has hardly been used. Can it be fixed
    Nov 19, 2008 | Cross Infoguard Shredder SX102M
    Infoguard shredder jam
    When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
    Jun 03, 2007 | Shredder 1052 (Cross-Cut)
    756 people viewed this question
    Top Aurora Electronics Office Equipment & Supplies Experts
    Jim Keysor
    ka4iup
    ka4iup
    Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
