Question about Homelite 'Yard Broom' Leaf Blower
I am trying to start my homelite leaf blower but i dont have the starting instruction sticker that came on it. the sticker had all the steps on how to adjust the two valves, throtle and choke. so if someone could give me a link where i could find it i would be very thankful.
My home lite has no spack
Posted on Apr 18, 2012
  • 246 Answers
Hello ben_brumett:
On My Homelite Blower I Simply Set the Throttle Lock. Pull Out the Choke (on the other I Move a Lever) and Turn on the Switch. Now Pull Until it Starts or Attempts to Start. Remove the Choke and Allow it to Warm Up for 2 or 3 Minutes.
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
Posted on May 13, 2009
Blower Vac HBL26BVN. The plastic primmer button has split. I cannot get a relacement. Help
Try this link:
http://www.ereplacementparts.com/homelite-ut08544-vac-attack-parts-c-18807_18808_139650.html
Jun 18, 2014 | Homelite Leaf Vac Attack
Homelite yard broom II fuel tank removal
look up the unit on the Homelite web site, download the manual, it explains all the steps.
Apr 28, 2014 | Homelite 'Yard Broom' Leaf Blower
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Leaf Blower won't stay running
Hey .. Did you replace the inlet screen in the carb ?
or
Either the carburetor, block behind it, or the cylinder are loose. Common Homelite problem.
Let me know ....
Mar 27, 2009 | Homelite 'Yard Broom' Leaf Blower
Good spark feul in compresion hanber but dont
I suggest you open the fuel tank and "fish" up the fuel line hose with the filter attached. Simply blow out the filter. That should allow your engine to get necessary fuel to carbuetor. This is 90% of today's no start problems.
Mar 12, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
Nov 24, 2008 | Homelite Consumer Products MightyLite...
I have a homelite leaf blower model ut08544 that will not start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 19, 2008 | Homelite 'Yard Broom' Leaf Blower
Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
297 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
