Question about Refrigerators
Samsung SR-L39 fridge freezer switching off
Samsung SR-L39 fridge freezer keeps switching itself off and then on again, I have changed the sub pcb board as it had been affected by water and was rusting away, and now the interior light works, still switches itself off and beeps a lot then switches back on with more beeping, this occurs every few minutes...thanks in anticipation.
  • 1 more comment
  • fluffypup Sep 16, 2007
    Cheers will try that
  • jonkinstates Dec 07, 2008
    The refrigerator keeps turning itself on and off beeping as it goes on and off the Compressor fires up then it beeps and cuts off again all the lights on the display light up when it comes on
    Turned it off for 10 mins last week turned it back on and it ran fine for 7 days now its doing it again
  • giananti Apr 12, 2009
    samsung sr-lr9 keeps switchin off. inside light sometimes comes on not always. fed up always having to empty it. do i have to buy new one. if so it won,t be samsung...............from [email protected]
Tarsia upatvane
Posted on Aug 30, 2008
Try to cut the conection of the thermostat and direct the conection and then observe 2 to 3 hrs, direct the 2 wires. before you replace the new ones good lock
Posted on Sep 18, 2007
  • 67 Answers
Replace the thermostat of the freezer
Posted on Sep 16, 2007
SOURCE:
Bonjour, j'ai un r?frig?rateur samsung SR-L39 " no frost " qui se met ? biper comme si la porte ?tait ouverte alors qu'elle est ferm?e depuis longtemps et il le fait toutes les minutes... si vous pouviez...
1. Check for obstructions in the door. Ice at the bottom, food in door compartment sticking out too far, etc....
2. Make sure the seal on the door is clean(Mild soapy water)
3. If the fridge was moved and the door was removed and re-installed, make sure it is "sealing" properly.
4. Too high a temp will also keep the alarm going.
Good luck! If none of these, you might have to call service.
Mar 29, 2015 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Model SR-L39. "no frost" dec
The defrosted water that drains to the drain tank has leaked when the fridge is defrosting,it can be due to some puncture in the drain hose from the freezer ,specially when the temperature is high this can be more . You can set the thermostat a little lower to reduce the frosting , also keep a flat tray under the drain tank so that the excess water can be collected and disposed.
If you can check and see if the drain pipe is damaged.
Jul 02, 2011 | Samsung Refrigerators
Hi, SAMSUNG SR L39 stops to cool, even if everything seems ok, the fridge is on, the display lit, but food is not cold. Then turn off and turn on the fridge by the power button and everything seems to go...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Refrigerators
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
Please help - SR-S20 Samsung Fridge/Freezer turning itself off!
yes your loosding communication between the thermistors and the control
in most cases and can be solved by ensuring you have nothing else sharing a plug or circuit with the refrigerator,,,,,I MEAN NOTHING, dedicated breaker the whole nine yards.
Past that you need a new control board.
I can not save you a service call, but I can remind you to read your warrenty this 150.00 board is covered under the 5 year electronics warrenty
Oct 06, 2009 | Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
1,590 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
