Question about Whirlpool LEQ8000JQ Electric Dryer
Wont keep running.have to open door to restart every minute or so
Dryer starts runs 2 mins and stops. open door and close it and it will run for another minute or so.
  • 686 Answers
YOU MIGHT HAVE A BAD DOOR SWITCH OR A BAD CYCLING THERMOSTAT OR THERMAL FUSES ON THE BRINK. DO THIS GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PARTS 2986 CHECK THI PART FOR CONTINUITY. THEN LOOK FOR THESE 2651 AND CHECK TO SEE IF THEY FUNCTION BY TAKING THEM OUT AND APPLYING A LIGHTER TO THE SENSING SIDE YOU SHOULD BE ABLE TO HEAR AND FEEL THEM CLICK. IF THEY DO THEY ARE GOOD. THEN LOOK FOR 898078 IF YOU HAVE IT OR 904589 EITHER A THERMOSTAT OR DOOR SWITCH IS BAD. GOOD LUCK
Posted on Apr 17, 2009
I have a Kenmore 500 model # 110.68532700, sometimes it would work and run for about ten minutes then shut off, after about 10-15 mins you could run it again, sometime it would run fine tell the clothes...
see this possibles causes:
see the diagram attached
1) Test the main start switch for open 2) Test the switch door for open 3) Test any coonector for loose wires, or broken wires, or burn .4) Motor defective repair
Jun 09, 2012 | Kenmore 500 6952 Dryer
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
I have a Kenmore 90 series dryer..this summer it started to go on all by it's self, if the door was closed it just would start..we had to keep the door open so it would not run. that lasted a few months...
Have you called themanfacturer re this problem you either have a faulty door switch or your timer is defective.I suggest you talk to manfacturer or a good applince repair there could be a defect in the dryer so ask them
Dec 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Apr 21, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Dryer won't stop running
The hot wire runs through the start button as a bridge to complete the circuit until the motor centrifigal switch closes the circuit when running. Now if you manually start your dryer and the timer doesnt advance keeping the dryer on until you open the door or advance the timer manually then the timer is good but the motor to advance the cam is faulted. The second scenario is that the dryer is off when the door is open, but when you close the door the dryer starts. With the second scenario we have a closed circuit at all times. At this point you have either a stuck start button or the centrifigal switch is closed. Usually it is the start button on this model.
Sep 08, 2008 | Kenmore 67082 Electric Dryer
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Jun 14, 2008 | Whirlpool Dryers
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
