Question about Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
    Sniper:
  • 54 Answers
Fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Posted on Apr 17, 2009
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Apr 26, 2011 | Sharp MX-2300N Color Copier
Hello, I have (had) a paper jam on a Sharp MX2700N. I have removed all copies but am now advised to call for service Code H5-01. Any ideas?
after call for service, the machine will indicate an error code like H4, F2,etc. if you can give me the code i will know what to do
Feb 03, 2011 | Sharp MX-2700N Color Copier
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
Can you tell me what code FK1 means?
Your fuser has gone past 200,000 sheets of usage and it's time for a rebuild. You could reset the counter with sim code 24 but eventually it will clog up with waste toner and your rollers will tear up. Sharp has rebuild kits for your or you could just buy a new one.
Jan 07, 2011 | Sharp MX-3501N All-In-One Printer
Code U2-05 call for service code!
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
Apr 20, 2009 | Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Feb 19, 2009 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
2,015 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
