I have a Hp Compaq 6710b laptop my daughter has put a bios password now i am unable to use this laptop please help me
  • Thomas F. Schneider May 11, 2010
    Asked your daughter what word she put into it?
    Scholar:
  • 150 Answers
This site will solve your problem. http://www.tech-faq.com/reset-bios-password.shtml
My suggestion is to remove the CMOS battery from the motherboard and plug it back in. This is NOT the laptop battery that you plug the power cord into.
Other than this, the software on the site I posted the link to can be burned onto a CD and then booted from on startup, these will either give you the password or take off the password completely for you.
Please rate, thanks!
Posted on Apr 17, 2009
Why is Hp compaq 6710b WI-FI turned off in windows, it is on in boot up but turns off when windows boots switch will not turn it on ?
U probably are missing wifi driver try uninstallung the wifi drivers then restarting the pc so when the pc starts again it will automatically install the correct driver
Aug 28, 2014 | HP Compaq 6710b Notebook
I forgot my wifi password on a Compaq 6710b could anyone please tell me how i can recover the password?
go to download.com type in search bar "password recovery " or password recovery wi-fi there are free programs to find your wi-fi password
Aug 01, 2013 | HP Compaq 6710b Notebook
How to switch on wireless compaq 6710b hp laptop
You can also check to see if it is enabled in the BIOS.
Start Laptop and when you get to the HP splash screen tap F10 to get into the BIOS.
If you have a BIOS password put that in, then the main BIOS screen will appear.
Click on the ADVANCED tab.
Click on the "Built-In Device Options"
Check to make sure that these 3 settings ARE checked.
Wireless Button State
Embedded LAN Controller
LAN/WAN Switching
!Remember to save before you exit!
Log back in and hopefully you're Wifi will be enabled.
If It still does not work, you can check to see if the Drivers are installed in Device Manager
Oct 08, 2011 | HP Smart Buy Notebook
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
I have laptop hp compaq 6710b, it cannot boot & hard disk not detecting.
Step1: Go to the BIOS and select first boot devise as hard disk. If you get same problem or hard disk not detecting. Replace the hard disk. Step2:If BIOS is not showing replace the RAM and check it..
Thanks..
Feb 10, 2011 | HP Compaq 6710b Notebook
MASTER BIOS PASSWORD
OPEN LATOP FROM BACK SIDE REMOVE & REPLUG BATTERY
PASSWORD WILL BE RESETTED.
Feb 07, 2011 | HP Compaq 6710b Notebook
How can i break up the Password of BIOS my LaPTOP Compaq 6710b I have purchased used Laptop
Its not possible to break BIOS password in case of a laptop, you have to go to HP service center for this. You can do this in desktop very easily by just taking out the CMOS battery and then reinserting it.
You can DO the same in your laptop also to remove the password but its highly risk cos once you opened your laptop your warranty will break if your system is under period. SO i wont suggest you to do it by yourself, better go to service center..
Nov 11, 2010 | HP Compaq 6710b Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
How do you remove the power-on password for windows Hp compaq 6710b?
Sadly, you must pull the laptop apart and reset the BIOS...well unless you know the password, then just remove it through BIOS.
Jul 16, 2009 | HP Compaq nx6110 Notebook
Computers & Internet Logo
486 people viewed this question
David Payne
David Payne
