Question about Sony PlayStation 2 (PS2) Console
Playstation 2 Disc Read Error
When I put a regular PS2 game in, it does not load, it goes to the browser screen and when I access the browser, it says it is reading rhe disc then a disc read error comes on the screen... but when I put a regular PSOne game in, it loads right away with no problems. I have the 5000 series PS2. Can you help?
  • Anonymous Nov 22, 2007
    My PS2 does not want to read any discs. When I go to the browse option it indicates " no data on disc".
    Scholar:
  • 68 Answers
After extensive research on this subject and working on several Playstation II systems. I found out the reason your system will play only blue disks and not silver is a alignment problem with the laser. It could be tilted or set to high or low. The quickest solution is to call Sony and get a new laser with the shuttle. If i am not mistaken it cost 50.00 and just go to the playstation site select support and it will explain in full detail how to take your system apart and replace the laser and shuttle.
Posted on Sep 16, 2007
SOURCE:
Doesnt read games...
there are various reasons
1. it can lens problem:--- change the lens
2. it can be your browser ic problem or even loading Ic
try playing original audio cds if it play u can conform it is lens problem
Mar 20, 2010 | Sony PlayStation 2 (PS2) Console
Ps 2 wont read game disc, goes straight to browser setup.
Your PS2 lens is probably weak or its dirty.You should try to clean your PS2 lens first.A dirt on lens wont let your PS2 lens to read your Game disc. Watch this video this will help you to know how to clean your PS2 Disc Reading Lens.
Try to place your PS2 at clean place and clean your PS2 regularly.
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
My action replay max (ps2) won't load!!
flip ya ps2 upside down when loading its the only thing that works for me lol
Feb 27, 2009 | Datel Action Replay MAX for PlayStation 2
Movies
About 99% of the problems where the PS2 stops playing movies, or certain games is a lens problem. The PS2 lenses are extremely sensitive and need to be cleaned regularly. I am betting you also are seeing "Disc Read Error" or "No Disc" on your screen when you enter the browser.
If this is so, you can get a "high quality" disc that cleans lens, or get a can of air that people use to clean keyboards. If you use the canned of air, you want to be sure to blow of the lens itself and not just blow air through the system, which would do no good.
Feb 15, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc read error
you will have to take it to someone who fixes ps2
Jul 20, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Sounds like a disk read error alright. Try replacing the laser eye device in the PS2. I know a good place with pretty low costing parts for PS2s. RichsPSXParts. If not the laser eye try the ribbon cable between the hard drive and the laser eye. Those I'd think be the most obvious first checks. I'm not 100% on it since every one I know whos PS2 does that wont let me look at it instead the throw it away. Such a waste.
Apr 10, 2008 | Sony PlayStation 2 Slimline Console
My new ps2 game wont work
if your ps2 is old, it may not take certain disks e.g. purple backed disks, dvds and a disc read error problem will appear in the browser
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Disc read error
Your PS2 lens is faulty or it is physically jammed in it's metal rod which stops the lens to move smoothy. you better open the PS2 console and observe it offline for jam. or replace the lens with a new one.
Nov 15, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Problem
Your laser is stuffed you need a new one. They dont cost that much.
Aug 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
210 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
