When i start my car it makes a ticking noise .. it sounds like a clock,.. what might it be
SOURCE: ticking and rattling sound
sounds like the problem is brake related. That ticking you're hearing is your front brake rotors, clicking against the sides of the brake caliper. As you speed up, the clicking will get faster untill you won't be able to hear it, (it's still there, it's just inaudible at such a rapid revolution) upon deceleration, you will notice it more prominently, clicking in rhythm to the speed of your wheel's revolution.
basically, It indicates your brake pads are worn down. Unfortunately the condition will get worse, louder, and the car will become extraordinarily more dangerous to drive as front braking will be compromised if the vehicle's braking conditions persist.
A qualified mechanic will setup the brakes, rotors, check for warpage, hone the rotors if need be, and be able to install a proper replacement pad.
SOURCE: clicking noise in the front end when making turns
Most likely this a broken CV joint and this means replacing the axle.
SOURCE: Ticking noise when starting car.
Check your oil level. It sounds like automatic lifter or tappets are draining and have to be pumped back up. 2007 is fairly new but if you don't change your oil often this will happen.
588.00 sounds ok for the brake work if they replaced the front rotors, rebuilt the front calipers and resurfaced the rear rotors.
SOURCE: 2001 Buick Century Ticking Noise
Okay, lets hope it is something simple. Remove the underhood light bulb. At night, in the dark, start the engine and look under the hood. You may be able to see sparks jumping. This would be bad wires. If you can see where the spark plugs go and one has a spark jumping it is just one bad sparkplug. Turn off car-replace underhood bulb.
If you see no sparks then it is most likely the valve train. If you have adjustable lifters they need someone to tighten them up to specifications. If they are not adjustable you may need to replace worn parts.
Make sure you keep fresh and plenty of oil in the engine. It can not repair worn parts but if the oil is low or dirty you will have bigger problems.
SOURCE: 2002 hyundai santa fe - engine noise ticking
The cam chains have developed slack and are slapping on the cam chain guides which helps prevent the cam chains from popping off in case of slack developing . The chain guides are made of some type of plastic material and develop significant wear.
