Question about Amana ALG331RAW Gas Dryer
Gas dryer won't start
When I push the start button there is only a humming sound. It is an Amana.
  • nancy399 Apr 17, 2009
    I took off the front panel and the belt seems good. What should I check for next?
  • 686 Answers
REMOVE YOUR ACCESS PANEL AND SEE IF YOU HAVE A BROKEN BELT IF NOT REPOST. ACCESS PANEL LOOKS LIKE IT COMES OF BY 2 SCREWS AND RAISING IT UP AND OFF.
Posted on Apr 17, 2009
  • James Chandler Apr 18, 2009
    post me the model number ok?
  • 105 Answers
SOURCE: I have a whirlpool gold gas dryer model
You either have something caught in the blower or you have a bad motor. If you unplug the dryer and pull it out. Then remove the rear panel (1/4" hex screws), looking at it from the rear, the blower is on your left. Remove the two screws that hold the blower housing on. You should be able to get your hand in far enough to see if there is something in the blower.
Posted on Apr 08, 2009
  • 58 Answers
SOURCE: My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
Posted on May 05, 2009
maddogsteve1
  • 18 Answers
SOURCE: Gas dryer won't start.
if the motor hums when you push the start button but wont move you probably have a frozen motor. happens from too much lint packed around the motor and ruins the bearings. if you can access the motor from a front kick panel you can check this. possibly something is jammed in the blower wheel as well. unplug it and check it out
Posted on May 24, 2009
  • 121 Answers
SOURCE: We push the start button on the dryers it does not
Sounds like you have a defective timer.
Remove the back cover of the control panel. Locate the timer and check its condition. The contacts may be burned.
Posted on Oct 11, 2009
  • 11 Answers
SOURCE: Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Posted on Jul 24, 2010
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Jul 23, 2010 | Amana ALG643RB Gas Dryer
When i turn on the dryer all i get is a humming noise, when i push in the button to start nothing happens
Usually this is a sign that either the motor is in a bind or bad. Sorry to say but the latter is usually the case.
Jan 26, 2010 | Amana DLG330RAW Gas Dryer
When I push the start button, the unit just buzzes or hums.
You have a broken drum belt. The hum you hear is the motor spinning at high speed.
Apr 21, 2009 | Maytag MDG2706A Gas Dryer
Dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Dryer won't run
Its time to call the repairman. If its the motor humming its either bad or the dryer is froze up and unable to turn causing the motor to hum. Eventually it will trip the breaker.
Nov 06, 2007 | Amana ALG331RAW Gas Dryer
Amana ALG331RAW Gas Dryer Logo
212 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
