Maxtor 40gb hard drive
Need illustration of jumpers... mine has 3 sets of 2 then a single on bottom. and another single set of 2 hoe do i set the jumpers 4 master
  • 4 more comments
  • bochi Sep 18, 2007
    ok Panth3on,
    the 40gbMaxtor model no.54098H8or(N256)man,in2000
    that is the master...
    the 260gbWesternDigital modelWD2500JB man,in2007
    is the slave
    i'm running them in an old HP Pentium 3 with a dimond pci ati video card 256mb
    with either XP Prosp2 or XP MCE SP2
    right now it won't even boot unless in safemode
    it was running fine untill updates from micsoft
    any sugestions would be great...
  • bochi Sep 19, 2007
    Panth3on,
    i have about a hundred or so movies on the wd 260gb and about 1000 songs so i'm not gonna lose that so i think i'll just get a new hard drive to
    replace the 40gb and do a new install on that...
    what do think should that fix my problem?...
    well originally i had a 60gb in place of the 40,
    but it crashed and wouldnt take a new install so i put in the 40..it worked great until dun dun dun..
    MS update...ya know ithink i'll just avoid the whole mess if i just don't use that.$^&t from MS
    do you have a sugestion on a hard drive to purchase... i think thats my best bet...do you?
    Bochi...
    by the way ...you rock dude!!! thanx!!!1
  • bochi Oct 05, 2007
    Hi panth3on,
    it's bochi! long time huh?
    the last problem is solved! thanx!....
    got another computer with a prob!!..
    it's probably a simple fix....I'm just missing it!
    Pentium 2 with xp pro sp2.....it has a network adapter in it! but the computer doesn't recognize it....no matter what i do...am i missing something? tried installing some drivers from MS...and it still won't see it! even tried a different nic card...nothing all (10/100 pc type)
    any help you could give?
    thanx again dude!
  • bochi Oct 06, 2007
    hay panth3on!
    i tried the setup bios?...no luck yet....i used the F1 to get there? (Gateway Pent.2) turned on the plug and play settings...power is on in the lan setting...what am i missing?....aahhhh!..i thought this was easy when i started?!...any help would be appreciated, and needed!
    thanx again dude!
    Bochi!
  • lambof Jan 04, 2008
    hard drive is not recognized by computer when pluged into usb port
    tried replaceing cords power turns on but still computer does not recognize device. any help
I think it's a conflict with the two hard drives maxtor (ata) and westen dig(eide) ,.....could be wrong....maxtor 40gb....west,260gb let me know
Posted on Sep 17, 2007
SOURCE:
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper setting
The first jumper goes up and down on the two pins just beside the IDE cable slot and the other jumper goes across the top two pins next to it
Jan 23, 2009 | Maxtor Hard Drive
Maxtor PLUS 8 7200RPM IDE ATA 133 40GB hard drive. Do i need jumpers and software for the install of this harddrive and if so here can i get. Thanks j
are you mounting it as the only drive or with another one... if you are mounting it as a slave usually you don't need a jumper... the jumper setting will hopefully be on the sticker.
xp and up will autodect the drive..
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Open Questions:
Computers & Internet Logo
6,854 people viewed this question
Ekse
Alun Cox
