Re: Infinity Bass link has no power. Both fuses are
What the problem is that you have a bad ground one way to tell is run the ground to your battery ground and i bet you it will work it happens all the time
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
Does the servo led stay on? If so, you might have a fractured solder joint. Inspect the switch control PCB for fractured solder joints and check the Positive and Negative 15v outputs on the same board.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
this is probably due to the box they are in. it seams that your box is tuned to a lower freq then the bass hits that are popping. message me with the box dimensions and the speaker parameters
Ok thanks I will give it a try.
