Question about Maxtor OneTouch II Hard Drive
Gets flashing light on start
Will not communicate w/ laptop. Maybe a power surge caused this. Any reset capablilities?
  • danw Sep 18, 2007
    Found out the answer on another forum. Went to Altex Electronics (or CompUSA would work) and purchased (about $50) a 5.25 Aluminum External Enclosure ME-340F Series. On the side of the box it is specific for IDE to 1394A (firewire) which is all I need. Did notice on the box they have one for USB 2.0 and 1394. Took the Maxtor case apart, removed the hard drive and connected it inside the new case/power supply. That new power supply did it. It doesn't look as presentable but IT WORKS. Back in business and boy was I sweating that one. Had a lot of back up stored there.
  • danw Oct 06, 2007
    I did not have any flickering going on, the computer just stopped recognizing the drive. It was very easy taking the Maxtor apart and converting it into the new box/power supply. The connections were pretty much bullet proof. Altex offered to do the work for $35 (1/2 hr). I'm sure they could tell you if your power supply is damaged. The only problem I have now is that the new box has no face cover and the hard drive is visible and a little loose inside. I don't really care because it works.
Danw, i'd like to ask more about this, since I seem to have something similar on my maxtor onetouch 3 - seems to have happened during a storm, so I think a power surge killed the power supply, and I don't think there was any actual disk/plate failure. 1. power on - the light just flickers for a while, then goes out. 2. the light on the power adapter is on, indicating that it works, but when I turn on the drive, the light on the adapter flickers, too. does this sound like the symptoms you were seeing? I don't want to take any chances with the amount of data I have on this 160GB drive... Thanks, Geoff
Posted on Oct 06, 2007
  • Geoff Siebengartner Oct 06, 2007
    by the way, Seagate/Maxtor will replace the drive under warranty, and they want to charge $1400 for data recovery!!!
    Scholar:
  • 136 Answers
No resets anywhere, Try it on a diff computer. Possible harddrive failure. Could be power supply problem.
Posted on Sep 18, 2007
My computer all lights start flashing. i can't boot
Andy,
Check for bad battery as this is the likely culprit. All laptops require a functioning battery to power up. Years ago manuf. re-designed this because people were using laptops without batteries and would get micro-surges that trashed their mainboard so most if not all laptops require a good battery in place to power up.
Let me know if that does not work for you and we'll look at some other areas
May 18, 2014 | ASUS G73JHA1 Notebook
Power surge, nothing working
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 10, 2013 | Acer Ferrari Computers & Internet
Standby light blinks 4 times
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
May 07, 2011 | Sony KDS-R50XBR1 50" HDTV
I have a Mitsubishi projection model WS-B55 that is plugged into a surge protector. The power went off for about an hour or an hour and a half this morning, and the power light is flashing. I called...
First, to answer your last question, not all power outages and subsequent surges are created equally nor are all surge protectors. Also, after a power outage where the subsequent surge is so strong that it got past your surge protector and knocks out your TV and it's never done that before... REPLACE YOUR SURGE PROTECTOR.
However, that being said, in my experience it is unlikely that the TV is going to require a technician. Understand that the person that you spoke with in tech Support is not a technician and is reading off of a list of troubleshooting pages that are more extensive then what's in the manual. What the technician is probably not aware of is that your TV, like most home electronics, has a safety failsafe that requires the device to be separated from power completely before doing a system reset
First, after pressing the button it's supposed to flash for about a minute anyway but I'm assuming that after it's done pressing that the TV is still not firing up.
Unplug the TV, let it sit for an hour, plug it back in (to the wall, not the suspect surge protector). If the light is still flashing, press the reset button again and wait for it to stop flashing and attempt to turn it on again. If it doesn't work, unplug the TV, follow the same steps however, let it sit for 24 hours before plugging it back in. That length of time is not common but some sets do require it.
If none of this works, then I would say that it's time to call a technician.
Nov 22, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Fan @ compressor wont run,one light is flashing
flashing light is showing an error code. if the unit is under 5 years old it will be covered under warranty.. if you want you can try and reset the power by turning it off at the isolator next to your outdoor unit, leave it a couple of minutes and switch it back on. this will reset the fault code, if the flashing light comes back there is a definite problem, if it runs the fault may have been caused by a power surge or something
Dec 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Command unit on 2001 model s class sat nav does not read disc, now cd says no disc boot cd cartridge is in place in the boot. Where can I get it replaced?
I believe that the command systems have an updated software kit and you can have it flashed at the dealer. I have never seen the flash software at an independent shop. Although you can have the c.d. drive replaced at any reputable mercedes repair facility because they will have to have a command capablility software to communicate with the unit. I would try to remove the power fuse and disconnect the power for 10 minutes to drain the capacitors and see if the power cycle resets your disc drive. you should have a fuse schematic either in the l. side of your dash under the plastic cover accessible with the driver's door open or in the tool kit in the trunk orin the l or r side of the trunk in a foam insert-they put them in various places in various models and I do not recall exactly which spot it is in. I hope I have been helpful.
Jun 30, 2009 | 2001 Mercedes-Benz S-Class
No power whatsoever, but...
Try taking the battery out and running the laptop with just the AC adapter.
Also you should use a multimeter to test your AC adapter for voltage. If there is voltage from your AC adapter and the unit will not turn on with the battery removed then you have a faulty motherboard or another component in the laptop.
If it works without the battery all you need to get is a new battery or live with it without battery.
Sep 16, 2008 | Computers & Internet
Red light bflashing
Sometimes a power surge will cause a projection back TV to shut down and flash like that. If you unplug it from the wall and let it sit for a minute and then plug it back in, it should reset itself. If that doesn't work it will probably have to be serviced. If it does work, make sure you get a nice surge protector so you don't fry your TV.
Dec 28, 2007 | Toshiba TP55H95 55" Rear Projection...
Maxtor OneTouch II Hard Drive Logo
465 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
