-   We just installed our new dishwasher. The water only seems to be lukewarm. There is no steam or drying at the end of the cycle. We've checked our water heater and we're sure that the heated dry function is engaged. How do we fix the element?-   l_mon13
Nov 23, 2007
-   My Wrilpool Quite Partner II seems to wash the dishes fine, but when it comes to drying them it falls very short of dry.
This has been the way it has operated from the first day I installed it.
most dishwashers have a front panel at the bottom under the door that unscrews, some have no base so access is gained by just looking underneath, some have a plastic removable base so access is gained still by the underneath, if no problems with the element there could be a supply fault to the element, it has been known for wires to become broken inside the door near the hinge but check all other variables first, if i have helped rate me please
A5 keeps coming on through the programme changed the inlet valve and worked o.k.for 1/2 a cycle the...
(More)
A5 keeps coming on through the programme changed the inlet valve and worked o.k.for 1/2 a cycle the same fault came on model no ZT6810 If i add some water it runs ok until fill required washes great when I do this
