Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Overfills/cold water will not stop pouring in
Hi, My washing machine will not stop filling.  When it gets to the agitating wash cycles, the process begins but the water continues to flow into the tub.  I have noticed it is only the cold water.  Even when the machine is completely off, the water just pours into the tub.  I have to keep the water shut off at the pipe and watch the machine like a hawk when I wash a load because I can't afford to have a repair man come to fix it!  Thanks.
  • jewelbug97 Apr 17, 2009
    Thanks, will try that!
  • 686 Answers
CHANGE THE WATER INLET VAVES
Posted on Apr 17, 2009
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jan 21, 2010 | Kenmore Washing Machines
    It keeps getting stuck on rinse cycle a
    Check it out....
    Good Luck!!
    thanks
    Jul 19, 2009 | Fisher and Paykel Washing Machines
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
    May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    GE washer does not agitate. Water does not stop filling.
    If it does not agitate at all, then it is either the motor, the clutch/motor control or the agitator.
    If the machine start agitating only when you advance manually the control knob, and at the same time is overfilling, that is probably because of the problem with the water inlet valve, or the water level switch, and that is also cusing the cycle to stop.
    See:It's overfilling
    Nov 20, 2008 | Washing Machines
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
    204 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
