Question about LG DLE7177 Dryer
Lg DLE7177 dryer
Considering this model. What does the 4 way venting mean? My laundry room is very narrow and we had trouble with the inatallation of the venting for the previous dryer so it sticks out alot past the counter.
    New Friend:
  • 60 Answers
It means the duct work inside can be reconfigured to go out the back, the bottom or either side with some additional pipes.
Posted on Dec 20, 2007
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
Lg Gas Dyer, "cooling" light is on and there is no heat
Most likely the igniter needs replacing tho it also could be thermistor or lack of gas flow or a few others.
Feb 15, 2018 | LG DLG2524 Gas Dryer
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 16, 2009 | LG DLE7177 Dryer
LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Oct 21, 2008 | LG DLE7177 Dryer
Lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
May 18, 2008 | LG DLE7177 Dryer
Whirlpool electric Dryer has water in vent
take the vent hose out of your dryer and try to dry the clothes, if it works your dryer is fine and the vent is clogged
May 10, 2008 | LG DLE7177 Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
LG DLE7177 Dryer Logo
276 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
