Question about Brother SE-270D Computerized Sewing Machine
Brother SE-270 race wont hold bobbin case in place
My Brother jammed while I was embroidering. I finished my design and then when I started the next one, It jammed and said the safety device had been activated. I cleaned the bobbin case and race area, re-threaded, changed needle. It was still jamming. I removed the embroidery hoop and took off the throat plate and bobbin cover. I moved the needle by turning the wheel. The needle goes down once fine but then the bobbin case rotates and the needle hits it the next time it goes down. The little protrusion on the bobbin case is not hitting the silver spring. The piece the silver spring is attached to seems to be moving (loose). Can I tighten this anywhere or will I need to replace this part? What is it called? Is there anywhere that has a diagram? I have seen several people that seem to have the same problem but no one has given a solution to fix it. I would appreciate any help. Thanks.
  • 110 Answers
SOURCE: Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Posted on Dec 12, 2007
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
SOURCE: Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Posted on Feb 04, 2009
  • 192 Answers
SOURCE: embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
Posted on Apr 20, 2009
  • 192 Answers
SOURCE: I have a husqvarna Designer SE. After
Most likely the thread is riding up and out of the tension disks. Look for the small, round opening in the pre-tensioner. It is the metal piece to the left of the horizontal spool pin. If the thread is on the horz spool pin, it will travel in the rounded opening. If the thread is fed in higher up, it can ride up higher in the pre-tensioner, causing it to not be pinched by the pretension spring and it may ride up and over the top of the tension disks. If this is a possibility, rotate the horizontal spool pin out toward you. Place a spool cap on it and feed the thread around it on the right side and below so the thread feeds into the pre-tensioner horizontally and I think that your problem will go away.
The only reason for this to happen is that you are loosing the upper tension for some reason so if my suggestion doesn't work continue to look at the upper tension assembly and the takeup lever.
Posted on May 19, 2009
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Apr 03, 2011 | Brother SE-270D Computerized Sewing...
Needle up down moves the embroider
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached.
It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving.
If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Jan 05, 2010 | Husqvarna Designer I
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
I have a brother SE 270-d. my only problem is that while embroidering, the bobbin thread is showing through the design on the top. I have tried adjusting the top thread tension but no matter how I adjust...
Try making the material tighter in the hoop and check your bobbin to be sure it's a L (look at your instruction will show you which bobbin works and which does not. I say this because you have a tension problem...dont we all, Ha Ha!
Jun 22, 2009 | Brother SE-270D Computerized Sewing...
Bobbins for se 270-d
I have the same problem! I also have the same problem with the ULT2001. The SE270D is a class A bobbin if I'm not mistaken. I've tried ALL kinds of bobbins and did not repair the problem. I stopped embroidering w/it for a while and only used it for sewing. It started embroidering ok for now. As far as oiling - I researched this last week when the motor locked up. You should be keeping the bobbin area (pop the plates under the sewing foot off) and make sure you don't have lint building up there. But the best I found, DON'T OIL. I couldn't find anything anywhere that would tell me where to put oil. What I did find was that you should take your machine in to be serviced about every 300-500 hours of use.
Aug 18, 2008 | Brother SE-270D Computerized Sewing...
Thread adjustment
Sounds like the bobbin tension is loose. Look at this website on their "repair" page where it explains how to adjust the bottom(bobbin) tension.
Mar 05, 2008 | Brother SE-270D Computerized Sewing...
Embroidery Problem with my disney
Check your bobbin case. Thread the bobbin through your bobbin case while holding it in your left hand. Pull the thread with your right hand and feel if there is any resistance. If not, you need to adjust the tension on the bobbincase. Also check if a piece of thread or fluff did not get stuck between the tension blades on the bobbin case. If you are not sure how to adjust the tension on the bobbin case, ask your dealer to do it.
Dec 18, 2007 | Brother SE-270D Computerized Sewing...
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
104 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
