Question about Durabrand DWT1905 TV
No sound on TV
TV on and I put DVD in DVD player, plug out TV connector from VCR to DVD, but no sound, I adjust the TV volumn, still no sound. Turn off TV and reconnect TV with VCR, no sound, and reconnect TV with DVD, no sound.
  • 2 more comments
  • Anonymous Feb 07, 2008
    no audio
  • namegame58 Mar 22, 2008
    olevia lt 20 s has picture but no sound. Finally got tech support who says is moter board problem @ $73.00. Is this an easy do it your self, is it worth it?
  • Anonymous Jun 28, 2008
    Plugged in a "plug and play" game, turned tv on, no sound. Unplugged game and there wasn't any sound. Now the tv doesn't have sound!
  • Anonymous Jan 20, 2009
    tv show picture but now sound
In that such problem the best solution is to buy another new. . . .
Posted on Nov 26, 2007
    An expert who has answered 500 questions.
  • 556 Answers
If you do not get result you can purchase one video rf converter. Rf converter contains one video input in yellow colour and two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in which place you receive dvd signal.
Posted on Sep 17, 2007
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
I'm trying to connect my denon dvd player to tv
The yellow plug is composite video; the red and white are analog audio. Not knowing specifics about your TV or Denon model number, I would suggest:
-- the red and white connectors go to the audio in on the DVD, and to the audio out on the TV. There will be a left channel and a right channel. Make sure you connect the same color plug on the same channel. In other words, if you put the red plug in the right audio out on the TV, also put the red plug in the right audio in on the DVD, the white in the left audio out on the TV and in on the audio in on the DVD.
-- the yellow connector will go on the video out on the TV, video in on the DVD.
For better audio, consider using gold connectors, if you don't already have same.
Alternatively, you may wish to purchase and use an S-video connector if your equipment allows. This would replace the yellow composite video cable, and enhances your image.
Hope this helps!
May 22, 2009 | Philips Magnavox DVD/VCR Dual Player
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
How to connect?
Get a three-way aerial connector for the back of your TV. It'll only cost you about £1. All it is, is an extra aerial socket where you can attach you dvd player.
It has 2 Female and 1 Male connector on it. You put the Male connector into your TV where the aerial goes. Then plug in your Aerial into one of the Female connections. Then plug in your dvd player via the coaxial lead ( not a scart lead) into the other Female connection. And turn on your dvd player and tune your Tv to pick up the dvd player. And hopefully that's it.
The connector your after look like a triangle shape with three metal bits sticking out where you plug in your Tv/dvd cables
Hope this helps
Jul 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung lcd-tv is making a buzzing noise
I have been having that same buzzing sound. It happens when you turn on the energy saver feature on the tv setup. Just turn it off. Smooth
Jul 15, 2008 | Televison & Video
Sound problems
Jun 18, 2008 | Onkyo TX-SR605 Receiver
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
VCR Playback
An "F" connector may be loose. Solutions: Check and hand tighten the cable fittings to the converter, TV set, and VCR. also: Adjust the fine-tuning on the TV set, VCR, or converter box. Good luck
Nov 27, 2005 | Emerson EWD2204 DVD Player/VCR
Durabrand DWT1905 TV Logo
235 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
