Question about Garmin nuvi 200W GPS Receiver
Has been working fine..now will not turn on.
I have a Garmin Nuvi 200 and it has been working fine. Now all of a sudden it won't turn on (even when plugged into the car charger). How do I fix this?
  • 469 Answers
It sounds like a dead battery?
When it is plugged into the car, you should see a charging symbol, or it will say charging if the screen is off.
Are you sure it is getting power from the car? Check the fuse for the lighter socket, also the power cord has a fuse in the end that goes into the cigarette lighter socket, if you twist the end of the adapter it should open and expose a fuse.
Check these fuses to be sure.
Hope this helps.
Posted on Apr 17, 2009
SOURCE: Garmin Nuvi 200
Guys go to
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=104952
http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
they have the answers
it seems a standard or phone USB cable will not work to charge and use the maps at same time
Good luck
Posted on Nov 15, 2008
  • 638 Answers
SOURCE: garmin nuvi 200 appears dead
If you've tried a hard reset and nothing happens, your ON/OFF switch might be broken. If it's still under warranty, return to Garmin for repair. If it is out of warranty, and you've tried all suggestions here, try this website. They replace the ON/OFF switch with a new one. Fixya.com is not affiliated with this website but they do seem to have a good track record.
Posted on Jan 14, 2009
  • 4090 Answers
SOURCE: garmin nivi 200 won,t turn on
well if the plug is not making contact it cant recharge. you need to have it repaired and that may well be costly as it will require a new motherboard. Parts are no longer soldered or repaired The motherboard will be repalaced and the basic board is ^$90 the labour 1.5 hrs o 2 hrs minimum at $95 I am sure you will be able to buy a new model for the same cost
Posted on Aug 01, 2009
SOURCE: Garmin nuvi 200 pick up charger as a usb cable
I can't give you a source of the problem but I can give you at least a temporary solution. Turn the unit on without the cord attached. After it comes up, press on the battery button for 10 seconds until the diagnostic screen comes up. Plug the cord in and press Exit and the unit should work while it charges. You will not be able to use it with the computer using this method, however. To do that you need to plug it in while either without powering it on or after it is powered up normally.
Posted on Sep 02, 2009
SOURCE: when i plug in my garmin to a car charger it
i just set the reset button in the back lid and it works, went totally dead earlier wow
Posted on Sep 17, 2009
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
My 2 yr old Garmin nuvi 200 was working fine...when I got home and turned the car off, it quit working and won't turn back on. I keep it plugged into the lighter, so it's not battery power.
No it's not the battery power: your nuvi has suffered the firmware equivalent of a stroke.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Sudden unreliable directions being given
I recommend you replace the firmware / system software of your Garmin Nuvi 200W.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 10, 2010 | Garmin nuvi 200W GPS Receiver
I bought my Garmin Nuvi 200 a couple of weeks ago but now it won't turn on even when I plug it into the charger. What can I do?
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
___________________
Jan 15, 2010 | Garmin nuvi 200W GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I hope that helps.
___________________
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
All of my Nuvi 200 settings (recently accessed, favorites, etc.) suddenly disappeared. When I entered a new destination address, however, it still worked. What would erase my previous settings?
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I hope that helps.
___________________
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
My garmin nuvi 200 worked fine the first 3 times
Connect your GPS to your computer with the USB cable and this will charge the GPS internal battery. Of course your computer will have to be on during the charging process. After a few hours turn on your GPS and see if it now works. If it now works then go to http://www.garmin.com and register the GPS. While you are on line also download the latest USB drivers for your computer and install them. When you reboot your GPS should be properly connected to the computer for Operating system downloads etc.
Apr 07, 2009 | Garmin nuvi 200W GPS
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
You can download new maps..........free......................but..........
I had this problem last year with my garmin 200 and when I called they said that I was out of the 60 day time window for a free map upgrade but they would give it to me anyway. They gave me detailed instructions on how to download a new map free of charge but they didnt explain which selection replaced what I already had on mine.
As a result, I downloaded the wrong maps and have much less detail. Even though its the "2009" version, its less acurate than my old maps were. But its worth a shot, better than paying for them.
Oct 28, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
249 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
