Sanyo crt tv cp21fs2
Standby ok ht 8ov aprox switch on ht comes up EHT cracks on set then reverts to standbyAt switch on the ctv will go into standby within a few seconds
    Top Expert:
  • Televison & ... Master
  • 76,673 Answers
Is this a projection TV?
Posted on Apr 17, 2009
What is the EHT no of videocon tv model no CTV-SLIM seralis no. 06 05 026 not work
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 23, 2013 | Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
My sanyo tv have standby power. and then cannot switch the secondary switch
Hello, it sounds like a power supply problem. When the powersupply in the tv detects a short or a problem it automatically reverts to safe mode or standby. It could be just a resistor or it could be something else. If its just the resistor or similar you'd be looking at around $100. Get a couple of quotes and pick the best. Thank you, I hope Ive helped.
Mar 28, 2011 | Sanyo Televison & Video
EHT Faliure and kindly give me the alternate EHT details .
Hi Rayjanardank
Eht on all modern ctv is generated with in the flyback transformer , although some older tv set use a triplier unit feed with a 8kv pulse from the flyback transforme
To find out the one that you have got , if the flyback transformer as two controls A1 and Focus mounted on it then the eht is generated inside, if the Focus contol is mounted on the tippler unit unit .As you do not state the make mod No of tv i cannot be of any more assistant but you could cheek the A1 voltage on the crt base , if this is about 350/430volt then the eht should be ok. Hope this might help with your problem.
Regards windyhouse.
m.
Dec 03, 2010 | Televison & Video
Panasonic TX-29ps stdby LED only 2 seconds after switching to the network, everything else is dead. However, Switching PSU IC801 provides voltage to 5V for stdby.
check : H-output tangester / EHT output voltage line 12v /24v 180v check dyiod /capaciter / ragistance ..
if your tv set red led is cantinu on then standby tr.checked if ok then
cheked 5v ragulater ic or prosasor cristl and with canecting pf
1.open s.by tr. check pin voltage
if ok
then check EHT output section h-driver transfermor h-puls 2.1v ac
if not then check croma ic input voltage B+ is 8 v dc and canacting spaer.
Oct 19, 2009 | Panasonic TX-29S90X TV
Model #
The solder joints on the CRT board might have cracked and cause this symptom. What you are describing indicates that the red gun is intermitten, and the solder joints on the CRT socket itself (red cathode) or the red output transistor have probably cracked loose.
Aug 23, 2008 | Sanyo HT32744 32" TV
Sanyo crt tv model cp21fs2 standby ok instant on then reverts to stand by
check the power board module for any damaged components
Jul 19, 2008 | Televison & Video
WILL NOT POWER ON
isolate power from hor.output section. if voltage becomes normal 130v &it does not drop then power supply is ok. now check hor output for leaky compnents near eht specially capacitor & diode. check hor output tr. at last eht. you can clean print near eht.
Sep 10, 2007 | Sanyo DS24424 24" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
