Question about Dell Inspiron 4000 Notebook
Inspiron 4000 won't start
I recently bought 2x256MB SDRAM SODIMM modules (unbuffered, non-ECC) to replace my existing 2x64MB modules in my Dell Inspiron 4000 laptop. However, the computer doesn't even start at all! Is there any way of running a diagnostic on the computer? On the modules? I even tried plugging them in one at a time, switching sockets for each one. What's my best option?
  • cornbeefonry Apr 17, 2009
    Thanks for the suggestion. I installed the new BIOS, but my computer still won't start up.
    I bought them on ebay. I should probably assume the modules were DOA. I would really like to test them out though, but don't have another compatible laptop.
  • 3,940 Answers
Install the old RAM, download and install the A23 BIOS flash, then try the new RAM again.
Posted on Apr 17, 2009
  • IQUIT Apr 17, 2009
    Then the next question is where did you buy your RAM. Crucial.com guarantees compatibility, and so does Dell upgrade ram.
A need fix my tablet.
Tra to reset the tablet to factory defaults. Press the power and volume down button simultaneously for three seconds, until it starts. A menu will appear, where you can navigate with the volume buttons and enter with the power button (maybe different - here you have to experiment. Usually only down possible) Follow the instructions for factory reset.
Apr 24, 2016 | Axiom QP013AA-AX RAM Module - 8GB DDR3...
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
What ram compatible with intel845gv mother
Please find the details below:
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845GV
  • Error Detection Support: Non-ECC only
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 2.x Compliant
  • Thanks and regards,
    Anil.B.R
    Aug 17, 2010 | Intel Motherboard
    I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
    Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
    Slot 1
    Slot 2
    Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
    *Not to exceed manufacturer supported memory.
    • Chipset: Intel 845D
    • Error Detection Support: ECC and non-ECC
    • Graphics Support: AGP 4X
    • USB Support: 1.x Compliant
    Q: What memory goes into my computer, and will a faster speed be backward-compatible?
    A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
    Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
    Q: How much memory can my computer handle?
    A: 2048MB.
    Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
    Q: Do I have to install matching pairs?
    A: No.
    No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
    Q: Does my computer support dual-channel memory?
    A: No.
    Your system does not support dual channel.
    Q: Does my computer support ECC memory?
    A: Yes.
    Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
    Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
    Memory issues
    CHECK RAM ONE BY ONE, IT MAY BE POSSIBLE THAT THE RAM IS FAULTY
    Nov 09, 2008 | Dell Inspiron 9300 PC Notebook
    I have a P3 at 500MHz and was wondering with this Motherboard,
    The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
    The motherboard supports the following memory features:
    • 168-pin DIMMs with gold-plated contacts
    • 66 or 100 MHz SDRAM
    • Non-ECC (64-bit) and ECC (72-bit) memory
    • 3.3 V memory only
    • Unbuffered Single- or double-sided DIMMs in the following sizes:
    DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
    Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
    Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
    All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
    Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
    So the max you can go is 3 x 256 MB.
    Thanks and please take a moment to rate fixya.
    Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
    P4S8X-X motherboard. Latest list of compatable RAM 1.gb
  • Chipset: SiS 648
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Max Unbuffered DDR SDRAM: 3072MB
  • Graphics Support: AGP 8X
  • Jul 06, 2008 | ASUS Computers & Internet
    Dell Inspiron 2650
    Here are the specs of your RAM:
  • Module Size: 256MB
  • Package: 200-pin SODIMM
  • Feature: DDR PC2700
  • Specs: DDR PC2700 • CL=2.5 • Unbuffered • Non-parity • DDR333 • 2.5V • 32Meg x 64
  • MAX 512 MB
    Here is where I normally Buy RAM:
    http://www.crucial.com/store/listparts.aspx?model=Inspiron%202650%20Series
    May 20, 2008 | Dell Inspiron 2650 Notebook
    Dell Inspiron 4000 Notebook Logo
    160 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
