Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Motor fires off great and run good but at full speed after 15 mins it dies and won't start after 10mins it will start but at hight speed only after i get it going run good at 1/2 speed
  • Dean
    Dean May 11, 2010
    CHeck:
    1. Fuel breather open and in good condition
    2. When was carburettor last disassembled and properly cleaned
    3. Check for good spark
    Post results of above thanks :)
  • Paul Jun 01, 2013
    I currently have the same problem, all the research that I have done tells me that the Power Pack could be bad. The next test that I am going to perform is wait for the motor to die again and not start and check for SPARK
  • 17 Answers
I had a similar problem with my merc., turned out to be overheating due to a worn water pump impeller. It would overheat and die, then after it cooled down, would restart. Check to see if you are getting a good stream of water out of the, for lack of a better term, "****", usually located at the bottom of the powerhead, on the rear of the motor. If it\'s just dribbling, dripping, or dry you need a new impeller.
Posted on May 28, 2009
    Problem Solver:
  • 11 Answers
What Year? Have the coils checked, they are located under the flywheel, some have been known to act up over time due to heat because of age. They time between dieing and restart souns like they had time to cool off until overheating again
Posted on May 01, 2009
2002 vortex 4.3
spray the cap and distributor and all the HT leads with a water dispersant (wd-40 or CRC spray) Any moisture in the cap will cause a ht short circuit and any dirt tracks outside will do the same.
Feb 09, 2014 | 1987 GMC G2500
I have a 1999 yamaha v star650 runs great reg maint. But I get 15 min rides then batt goes dead I charge it with a small amp charger/tender shows full charge, turn on the key I hear a few clicks then fires...
Do a hydro test on the battery, replace the battery if below 1200. Check the reftact thing ... bridge rectifier ... for shorts. And of course check the alternator for output.
Sep 09, 2013 | 2007 Yamaha V Star Custom
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Fedders 5,000 btu window room a/c; blower won't run or runs very slowly. When it does get up to full speed, it only runs for a short time (10 or 15 mins) then blower stops.
Sounds like the motor is overheating and stopping after some run time has passed.
The issue with it not wanting to get going sounds like it may need oiling (if the oil type). Or it could simply be the motor is on it's way out and will soon die on you. In the latter event you sound like you need to replace the motor.
Sep 02, 2010 | Heating & Cooling
VSC--TRAC/OFF & CHECK ENGINE ON WHILE3 DRIVING
sometimes the fuel injection will cause the lights to come on because it's still in the motor and messes up the fuel and oxygen readings. Just let the car run for about 15 minutes, then disconnect the battery for about 20 mins. then start up. But disconnecting the battery will reset clock, and need the program windows.
Aug 19, 2009 | 2002 Lexus RX 300
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
313 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
