DVD player reloads after 5 minutes into the movie
We have a new portable DVD player from Digital labs. Hardly used. It plays movies, put after about 5 minutes, the "loading" screens comes on and the movie starts from the beginning. The movie will play for about 5 minutes again, and again the "reload" screen comes on. This happens whether you are using the AC adapter, the battery pack or plugged into the car outlet. Digital Labs K725 Portable DVD player
  • 3 more comments
  • O4GS Dec 26, 2007
    Movie never plays, it loads, then no disk found. BRAND NEW out of the BOX!! The DVD just keeps reloading and spinning and then STOP comes up when you click play. Then it just starts all over again! Any help?
  • hhheeelllppp Dec 29, 2007
    I have the digital labs K725 model also and mine plays the movies but the car adaptor does not work at all. I even went to radioshack and got a new car adaptor and it still doesn't work! Something is wrong with the whole dvd player and it's impossible to contact the company that made it since I lost the intruction manuel. Do either of you still have the instruction manuel? If you do, can you look for a number to call on it and post on here what it is? Thanks.
  • Anonymous Jan 01, 2008
    Mine K725 Digital lab DVD player just keeps loading and then shuts down
  • ladyday04 Jun 24, 2008
    I bought a K725 from someone at work for $50. They told me it worked, and blah blah. I played it, it worked. I looked at it and it seemed great and too good to be true. I took it home and it never worked again. I thought it was the AC adapter, so I bought another one, which I am going to take back tomorrow, the car adapter does not work, and its not even laoding the CD anymore. If I had know this I would have just bought a new one, but I do see that I should buy this brand anymore.Does anyone know any other things I should try or should I just trash it??
  • rubydood Jul 26, 2008
    Don't know what to do, I put a movie in, it says loading then quits and nothing else. I have the line to out. Tryed putting it on in and i get a blue screen, but it to out and i get a screen that say DVD Video. Can you help me please, I have a 4 yr old that is expecting this to work? Thank You
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
I had the same problems from this product! PERSISTANCE is the key!!
I tried to call the tech support numbers that the other people here had suggested, all I got was a recording that wanted me to leave my info and theyd "contact me in "0 to 2 business days".
Sorry, Im quite impatient .... had to keep fiddling with it myself, till someone calls me back. Hell, if I break it, it was already broke, right? lol
THE SOLUTION is to clean the lense! I stuck one of those disc cleaner discs in and shortly after, it started working just fine. Mind you, Ive spent at least an hour popping disc after disc, in .... thinking it was a problem with HOW a DISC played/read. I truely believe the player just needs to be cleaned of dust.
I suggest giving the device to a responsible child in your household, to mess with/attempt this (as MY mother did). She got this Portable DVD Player for X-mas and when it arrived from Ebay, she waited 2 months before seeing if it even worked. She was quite disappointed to find that "it was ****" and shed waisted her money. She gave it to me to try and fix, with no luck. So she tried numerous times to toss it out .... me, being a pack rat, holding onto it for 7 months, found I had nothing else to do today, remembering I had this thing, decided to give it another try. About an hour of persistance, its working perfectly fine, like brand new.
PUT A DVD CLEANER DISC IN AND SEE IF THAT FIXES THE PROBLEM, continue to try and play discs a few more times. If not, Im sorry I couldnt help ... but I tried. AND I promise, this did it for me.
Posted on Sep 26, 2008
My wife & I have a model k725 that had failed to start. We tried re-charging the battery until the l.e.d. went from red to green, then started the unit. The player would only start for a moment, then the red indicator on the player would lite, and shut down. After recharging the battery for overnight again, I tried once more and "snapped" the movie down firmly. The unit has since played on demand, so I'm at a loss of what was happening. If you're looking for help, in the owner's manual is a tech hotline. Starlite Consumer Electronics, @ 800-321-5976 or 612-344-4700. Also www.griffininternational.com is listed as the distributor for the U.S. Best of luck with your player. Gene
Posted on Dec 02, 2007
Here is the phone number for support. 866-387-2027
Posted on May 22, 2008
    New Friend:
I tried cleaning, recharging, plugging in, and unplugging. When the disc is loading (as this is all the machine will do), sometimes open flashes on the screen. Does this happen to anyone else? Perhaps this is why it keeps loading and slowing repeatedly. Anyone have any other ideas? Also, I went through a few numbers before getting the office I needed to deal with the problem. The number is 866-387-2027.
Posted on Jan 04, 2010
Response to Solution #4
You have listed Griffin International website as being a distributor for these DVD players. I work for this company and you have posted the wrong link, our company has nothing to do with these DVD players. I have received several calls about them and was trying to find where this was coming from. So the above link to Griffin International is in no way connected with Starlite DVD players.
Posted on Jul 28, 2009
    Problem Solver:
  • 5 Answers
Yea I had this problem where i kept putting my dvd into the player, and I kept getting a red light at the base and a blue screen. To fix it you hav to turn the line select from in to out
Posted on Jul 06, 2009
  • 3 Answers
If it is plugged in, unplug it. If not, try plugging it in... It has worked for me before. Also, if its brand new, I'd look at your warranty.
Posted on Apr 28, 2008
I finally threw it out and bought a new one. It will not work, I took it in to be looked at, you are going to pay more to fix it then to get a new one.
SOURCE:
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
My dvd player pdv 709 wont show the movie .it shows half
my Portable DVD Player just stop playing movies. i put a movie on and it want read or it will start the movie snd just stop and want play no more
Oct 23, 2009 | Durabrand PDV-709
Creative zen 8GB movies dont fit to screen!!!
When playing the video, click on the options button and select fit to screen. if this doesn't work, try deleting the video(s) and cropping them from the computer. then reload them.
Dec 26, 2008 | Creative Labs Zen Digital Media Player
The durabrand 1700
It could be the codec u use to encode the movie,
secondly could be a firm ware problem of your dvd player.
Other than this I can't think of any other reason. or just may be the type of recoreder u use or the recoding programe. If u had check these, then get another player
Sorry, this is all I can think of.
PS. the player firmware is the main reason to me.
Cheers
Rifaa
Nov 18, 2008 | Durabrand PDV-705 Portable DVD Player
Portable DVD Player problem
The inter lock is sensitive add a little length to tab mine did the same
Aug 28, 2008 | Televison & Video
My PDV-705 Portable DVD
Durabrand portable DVD players are no longer supported because the company that made them for Walmart went out of business last Novemeber. You can contact Walmart for a replacement unit.
Jul 29, 2008 | Durabrand PDV-705 Portable DVD Player
I WANT TO BURN MY DOWNLOADED MOVIES ON DVD-R &PLAY THEM ON A DVD PLAYER
I always use Aimersoft DVD Creator, it can easily convert all popular video formats (AVI, MP4, MPG, MPEG, 3GP, WMV, ASF, RM, RMVB, DAT, MOV, FLV, etc) to DVD and burn DVD movie played on portable and home DVD players, that's very good, you can check it out here for free:
http://www.aimersoft.com/dvd-creator.html
Apr 14, 2008 | Ahead Software Nero 6.3 Reloaded (60096)...
Wont play some newer rented DVD movies
If it is a blue ray, you need a blue ray dvd player.
Aug 26, 2007 | Curtis CMD5000 DVD Player
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Jan 05, 2007 | Apex Digital PD-450 Portable DVD Player
Televison & Video Logo
1,519 people viewed this question
Top Televison & Video Experts
Ekse
