Question about Tricity Bendix AW1000W Front Load Washer
Dishwasher stuck in cycle tricity bendix DH 104
Dishwasher is stopping in one part of the cycle.It stays running but it wont move into the next part of the cycle .I manually moved the cycle forward and it emptied the water and was not blocked. I refilled the salt and tried again to rerun it but the same problem occured.
  • Anonymous Jan 03, 2008
    have the same problem but the element still seem to be hot during the progress.
  • 209 Answers
If this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Posted on Sep 16, 2007
No power is coming into my tricity bendix dishwasher. It wont switch on. It was working perfectly
ensure the breaker has not tripped. Is your device controlled by a wall switch. Consult with electrician.
May 30, 2018 | Tricity Bendix Dishwashers
I have a tricity bendix dishwasher and it is not draining fully at the end of the cycle? If I run the dishwasher into a bucket the water pours out nice n strong. The waste pipe is not blocked, and I have...
Check the fitting where the dishwasher hose connects to the drain. If it drains when disconnected, it is either kinking the hose when you put it back in, or the drain is plugged at the connection.
Nov 19, 2017 | Tricity Bendix 18 in. DH090 Free-standing...
Hi there, I have a Tricity bendix dishwasher, approximately ten years old. the other night in the middle of the wash cycle, it went pop, tripped the mains at the board and there was a smell of burning in...
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Jun 29, 2017 | Tricity Bendix Dishwashers
Water stays in dishwasher goes through cycle but motor not going if turn propelers at back of motor pump kicks in for few seconds.is it pump motor ,is there brushes in these motors
Yes there are brushes in dishwasher motors it sounds like they are either worn out or stuck try tapping motor with the wooden end of a hammer at the rear of motor as brushes clog up as they wear hope this helps
Sep 05, 2009 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Jan 27, 2009 | Dishwashers
Tricity bendix dishwasher DH 086 stopped working after main wash cycle - never had any probs before with it.
the cold water wont come out, just get a load buzzing noise, I think its the water pump but want to be sure. Any ideas ?
Jul 12, 2008 | Dishwashers
Tricity bendix DH 103
Remove from hole. Place on back. You can gain easy access to pump.
Jul 04, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Oct 17, 2007 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity Bendix AW1000W Front Load Washer Logo
290 people viewed this question
Top Tricity Bendix Washing Machines Experts
jimorris77
Bobby G
Bobby G
Marvin
Marvin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
