Question about Dryers
Loud pop or thump noise then the dryer stopped spinning but the timer still clicks on/off.
  • 686 Answers
PROBABLY BROKE THE BELT POST MODEL NUMBER PLEASE
Posted on Apr 17, 2009
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
I own a whirlpool top loading washer - under 2 years old. it stopped draining water and spinning. replaced the timer and now it works fine, but now when the washer finishes spinning, the agitator stops...
depending on your exact mode;
sounds like a brake, or a clutch
those are really only two parts it could be
on the whirlpool the brake is part of the transmission on the direct drive
Oct 15, 2009 | Washing Machines
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud thumping while stopping after spin cycle.
make sure the shiping rod is out it will do that if it,s not out
May 29, 2009 | Kenmore 22422 Top Load Washer
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag dryer problem
sounds like the motor. if the motor gets too hot then the overload on the motor wont let it come back on until it cools off
Nov 25, 2007 | Dryers
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
