Question about Saeco VIA Venezia
Saeco classico is overheating
My machine overheats within 2 or 3 minutes after power on,i'm able to get good shot every now and then.It keeps heating up even after turning power off,Could this be a bad thermostat?I appreciate any info that will help me.............Thank You
    President:
  • 1,618 Answers
Yes. Check the thermostats on the boiler.
Posted on May 23, 2009
The steamer and heating element not functional
checke the power, if theres no power checke the fuse, if damage replace it
Jan 30, 2011 | Saeco Classico Espresso Machine
Water does not heat
More then likely it's the boiler.
Apr 26, 2010 | Saeco Classico Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Jan 20, 2009 | Saeco Classico Espresso Machine
Heat temp and time
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
No crema
Sounds like the handle where you put the coffee in needs replacement, if you leave the machine on for long periods with the handle on there is a metal spring inside with plastic parts that regulate the pressure in the tamping basket. 9 BAR is the desired pressure to produce crema. the plastic parts can melt and the spring looses tension. If you place the handle on, lock it, the it should shift slightly backwards on its own if you have to help it I have bad news replacement time. I have seen replacement from 25.00 - 90.00. I have two classicos and already replaced one handle and have to do the next. It could take one time of leaving the machine on all day. Good to get in habbit of turning off the machine immediately after use let it cool slowly attached to unit and clean it when you get home. Immediate cleaining in cold water could make the spring fatigue faster and also cause this problem.
If you are brave and can remember where parts were; take the three screws off where the coffee comes from handle slowly separate the parts and you will see if plastic melted, is distorted or spring is like mush.
Here is the saeco parts diagram and parts ordering site but I warn you its the most expensive
www.saecoparts.com/SaecoEspressoClassicoBodyparts.html - 70k -
Jul 08, 2008 | Saeco Classico Espresso Machine
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
May 28, 2008 | Saeco Classico Espresso Machine
Water Too Hot, Coffee Too Watery
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
Jan 01, 2008 | Saeco Classico Espresso Machine
Steam jet in Saeco Classico
Try Descaling your machine. A lot of times calcium will form on the inside of the boilers and on the heating elements in espresso machines causing heat transfer issue and clogged lines.
If the heating element cannot transfer enough heat fast enough then your steam will run out.
If you need a good descaler or descaling instruction visit www.CeriniCoffee.com
Dec 22, 2007 | Saeco Classico Espresso Machine
Saeco Classico is tripping the GFC outlet
Your machine has a bad heating element and is ground out to the boiler ground. You will need to have the boiler rebuilt.
If you need service you can contact Cerini Coffee Services in New York. More information go to www.Cerinicoffee.com or go to saeco's website to find a local service center.
Hope this helps!
Johnny
Sep 20, 2007 | Saeco Classico Espresso Machine
Saeco VIA Venezia Logo
200 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
