Question about Nespresso D300 Espresso Machine
Just says 'fill water'
Hi I have just been given a Nespresso Magimix M300 (also called D300 I think) by a friend and it was working fine at her house. Now I've cleaned it all up, put water in the tank but when I turn it on it keeps saying 'fill water'. Obviously it thinks the water tank is empty and the water is not going to wherever it is meant to go. Does anyone have any ideas please?
  • fab7000 Sep 23, 2008
    Hi guys, thanks for this tip.
    I cannot seem to let water run through it anyway. I am using the tap on
    the right side, and I dont know if i am doing it rightly. You guys
    mention that I should let water run through but without using the froth
    feature.
    I have no froth button or anything, all i got is the four buttons on
    the front display, and the tap on the right side. I can twist the tap
    on the right side 90 degrees towards myself, and then it says "water"
    in the display, and soon after that wants more water.
    Hmm.. what am i doing wrong?
    Best regards,
    Frederik
I cannot seem to let water run through it anyway. I am using the tap on the right side, and I dont know if i am doing it rightly. You guys mention that I should let water run through but without using the froth feature.
I have no froth button or anything, all i got is the four buttons on the front display, and the tap on the right side. I can twist the tap on the right side 90 degrees towards myself, and then it says "water" in the display, and soon after that wants more water.
Best regards,
Frederik
Posted on Sep 23, 2008
  • 3 Answers
This message appears everytime the machine empties itself of water.  You need to prime it.  The suggestion above to run water through it the steam wand is the right one.  No need to descale it!
Posted on Oct 24, 2007
Thanks for this. I did this plus some more descaling and it seems to be working, although it continually tells me it needs descaling now!
Posted on Oct 08, 2007
This has happened to me. try opening the steam wand (but without the steam function turned on) to force hot water out. that usually gets it going for me.
Posted on Oct 07, 2007
SOURCE:
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
How can I prime my M300 machine, we have tried all suggetions and so far no water leaving the tank
These machines cannot be repaired. Just get another one or trade it in. Either it works or it doesn't.
Apr 02, 2011 | Nespresso D300 Espresso Machine
Hi My Nespresso M300 has started tripping the RCD power protector in my house. Any suggestions on how to diagnose the problem ?
Check no water has got into the machine or into the power connector. If the power cord is removable like the one on a kettle with the same connector you could try using this on the machine and see if it works. The chances are there is probably a fault in the heating element allowing current to leak causing the RCD to trip and you may need to have this replaced.
Mar 12, 2011 | Nespresso D300 Espresso Machine
Manual instruction in pdf doc
The manual can be found at the following location:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
Mar 09, 2009 | Nespresso D300 Espresso Machine
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
Dec 28, 2008 | Nespresso D300 Espresso Machine
Try rescaling the machine.  The following is a PDF of the instructions:
Sep 03, 2008 | Nespresso D300 Espresso Machine
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Nespresso magimix M300
Sounds like it is deffective.  If it's under warranty (under 1 year old) Nespresso will pick it up at your residence and fix it/replace it for fre.
Aug 16, 2007 | Nespresso D300 Espresso Machine
Nespresso D300 Espresso Machine Logo
999 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Gerry Harvey
Gerry Harvey
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
