Question about Dell 962 Photo All-In-One InkJet Printer
This All-in-one can not support by D-Link DPR-1260 Print Server?
I use D-Link DPR-1260 Print Server, but on the server window shows this device but says scaner not detected. Is because D-Link not support Dell printer or anything can be set up? Please help. Thanks
  • 5 more comments
  • chou_tw Apr 17, 2009
    This print server has 4 USB ports. I have connected another all-in-one printer HP PSC 2110 to it, the print server detected it and scanner founction works great. The reason to add Dell All-in-one 962 is because it has ADF so I can scan multi pages easier. I just want to know is because D-Link not support Dell's printer or there is other way to config this. Thanks.
    I have just set Dell 962 to share and update D-Link's firmware and still the same. Attached photo shows port 2 no scanner detected but port 1 ok.
    It is D-link DPR-1260 Multifunction Rangebooster G USA Print Server. Thanks
  • JDTec
    JDTec May 11, 2010
    Did you run the wizard from the D-link's setup page?
    The manual is on this page.
    http://www.dlink.com/products/support.as...
  • JDTec
    JDTec May 11, 2010
    Give me the model of the D-Link unit.
  • JDTec
    JDTec May 11, 2010
    I f you are using the USB port, Did you configure the Dell to be shared over the network?
  • JDTec
    JDTec May 11, 2010
    When you use a printer server with a multifunction unit, the scanner will not be available. Most if not all printer manufacturers do not support their printers in this configuration.
Corysf62
  • 188 Answers
SOURCE: very strange problem with Dell 5100cn
Hi Dejoda89,
Unfortunately, the problem is not with the printer, but rather the computer that you are trying to access it with.
It could be a corrupt Print Driver, corrupt registry file, your firewall, or even the security settings on the print server.
The network card of the printer doesnt care where the source of the request is coming from. If you can address the printer via tcp/ip, then the port is active and working.
Check with the system administrator of the print server to see if they can help resolve the issue.
Posted on Oct 31, 2008
  • 7 Answers
SOURCE: Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Posted on Nov 10, 2008
vegakitten20
  • 685 Answers
SOURCE: DELL 1600n drivers for 2003 Server (Network Scan)
  1. Click the file name below to download the driver:
    R165289.EXE
    new_note.jpg Note: By downloading, you accept the terms of the Dell Software License Agreement.
  1. Click the Save button.
  2. On the Save As: window, verify that the R165289.EXE file name is listed in the File name: box, and then click the Save button.
  3. On the File saved window, click the OK button.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Posted on Nov 26, 2008
hillardx
  • 132 Answers
SOURCE: Is there a print server that supports a dell 946
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156036&cm_re=print_server-_-33-156-036-_-Product
Most print servers support all printer with that being said I would go with a linksys or trendnet. Trendnet most likely way cheaper as you can see its a wireless print server for under 70$. Hope this helps good luck to you.
Posted on Mar 06, 2011
SOURCE: When I add Dell 1600n
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&docid=55897&doclang=en&l=en&s=dhs
Posted on Dec 14, 2011
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Windows 7 compatibility forthe DPR 1260
My DPR-1260 arrived yesterday and I set it up easily in minutes on both Windows 7 (32-bit Pro) and XP SP3 with 3 printers attached. So far I have only tried wired connection. Wi-fi may be more problematical.
Printers are Brother HL-2040, HL-2140 and Samsung CLP-300. Could not get it to recognize my Canon Lide 25 scanner
Oct 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can not install
Chapter 3 - Configuration
This section will show you how to configure your new D-Link wireless print server using the web-based configuration
utility.
Web-based Configuration Utility
The IP address of your print server will be automatically assigned by your router.
To access the print server’s web-based configuration interface:
Windows® XP users:
Double-click on the My Network Places icon on your desktop. Your print server will be displayed as “DPR-1260:
dlinkps-xxxxxx” (where xxxxxx is the last 6 characters of your print server’s MAC address). If you do not see the print
server or have UPnP enabled, please refer to page 13.
Windows® 2000 users:
You will need to write down the MAC address located on the bottom of the print server (E.G. 00-54-23-45-f5-b6). Open
a web browser and enter the following:
http://dlinkps-XXXXXX
XXXXXX = the last six characters of your MAC address.
Note: Some printer software features may not work
while connected to the print server such as ink level display.
This will prove the print server is working. If you can not access the web interface then it may not be getting an address from the router
May 22, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-LINK DPR 1260 NOT DETECTED
did you install the software that comes with the print server? if so, did you configure the software to recognize the printer?
Apr 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260 with Epson CX6600 & Dymo Duo
The DPR-1260 is pretty easy to configure and works well with my HP Laser 1012, HP Photosmart 8250, and HP OfficeJet 5610. The Operating System on the computer is what matters... as long as it's running Windows XP, Vista, or a server edition like Win2003, you should be fine. I can't speak to the Mac environment, as I don't have any experience there. As for the Dymo Duo, I can't tell you how well it'll work in this environment, but based on my experience with it and many other print servers that I've tried, I can't think of a better configuration to try. Personally, I would recommend the DPR-1260 to anyone... just make sure you follow the installation instructions in the users manual carefully, and you can't go wrong. I love mine, hopefully you'll enjoy yours as well.
Oct 27, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Dell 962 Photo All-In-One InkJet Printer Logo
326 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
