Question about RCA P52936 52" Rear Projection Television
No light in middle rear projector of RCA p52936.
  • 398 Answers
The P52926 uses the PTK195 series chassis. The middle "rear projector" is actually the Green Picture Tube. If the red and blue tubes are working then all major components of the set are fine. The only things I can think of that would stop the green tube are cracked solder joints on the green picture tube socket PC board or an open high value (100k - 120k ohm) resistor on that board. If you do not have experience testing and replacing small parts or resoldering boards in a projection set then have a qualified tech handle it for you.
Posted on Sep 18, 2007
SOURCE:
Picture is distorted and colors are wavy almost looks like the picture is doubled and color doesn't look right
You can try a new lamp, use the convergence feature to align the three lcds inside. If it doesn't work, you need service.
Jul 30, 2010 | RCA P52936 52" Rear Projection Television
Sound but no picture. I'm thinking I need a new picture tube but how much is it going to cost me?
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Jan 30, 2010 | RCA P52936 52" Rear Projection Television
Hitachi 52" screen is broke need new one and screen behind that
Try www.partstore.com, they have a pretty good rep for parts.
When you get on site you will have to give make, model and possible part number.
Just follow instructions..
Mar 07, 2009 | RCA P52936 52" Rear Projection Television
Need a New Rear Center Lamp
IF THIS IS A PROJECTION TV ,,THE CENTER LAMP IS ACUALLY THE GREEN PICTURE TUBE-ANY LOCAL TV SERVICE COMPANY WOULD LOVE TO SELL YOU A GOOD USED PART- ..RCA IS NO LONGER --GO TO THE" THOMSON ELECTRONICS" WEBSITE FOR CUSTOMER SERVICE,,GOOD LUCK!!!!
Mar 22, 2008 | RCA P52936 52" Rear Projection Television
Owner manual
You will find the owner's manual in the link below.
P52936 Owner's Manual
Mar 07, 2008 | RCA P52936 52" Rear Projection Television
Visual and power problem
Bad high voltage transformer. Most original transformers are not made anymore by RCA.
Mar 04, 2008 | RCA P52926 52" Rear Projection Television
RCA P52936 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
