Cant get menu off screen
Our phillips 32" lcd model no#32pf7320a/37 goes to menu page on its own and now we can't get out of menu
    Novelist:
  • 159 Answers
What is actually the switch (is a touch switch) inside the tv. The button the user touch is a plastic same as the black or gray frame. a visible inspection can tell you if this plastic is doing the job because if you touch it actually clicks and you feel doing the function. if is different the way it works than the other buttons. That is the reason why the menu appears because the plastic is damage. the other possibility is the electronic switch itself is now close forever but inside. if those two problems are not the visible solution. a deepest trace has to be track to diagnose the final reason of the problem this is the micro controller
(by the way: isn't the menu button (remote control) dented or probably pushed in by accident)
Posted on Apr 17, 2009
My tv information at the top left of the screen will not go away i have pressed every button on the remote and still won't go away
Look in tv menu for:
SETTINGS / SETUP
MENU PREFERENCES
Set OSD to MINIMUM.
See page 15 of user manual at following link:
http://download.p4c.philips.com/files/3/32pf7320a_37b/32pf7320a_37b_dfu_eng.pdf
Good luck and let us know if it works.
Jan 21, 2011 | Philips 32PF7320A 32 in. LCD Television
I have a Phillips LCD tv model #42PF7421D/37. and
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
&scy=US&slg=AEN&sct=LCD_TV_SU&cat=TV_CA&grp=SOUND_AND_VISION_GR&session=20091111140139_64.85.227.44&ctn=42PF7421D/37&mid=Link_Software&hlt=Link_Software">Philips Support Page
Nov 11, 2009 | Televison & Video
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
My Philips flat screen tv model 37PFL5332D/37 will not come on...what should I do to reset my tv
The only way to reset it is to leave it unplugged for 24 hours. If resetting it doesn't help let it turn on, you may have to replace the power supply
Jul 09, 2009 | Philips 32PF7320A 32 in. LCD Television
Phillips 32pf7320 TV - Menu screen won't go away
i have the solution for this problem it is a software update that you have to upload to your tv if you have more questions email me at caypianan@yahoo.com
Jul 06, 2009 | Philips 32PF7320A 32 in. LCD Television
Menu on a Philips-32PF7320A-37B
try leaving the TV unplugged overnight (at least 8 hours). this should reset televison to origional defaut settings. If you are using a remote, you should use new batteries or put it in another room and use menu buttons on the tv itself it is equiped.
Mar 31, 2009 | Philips 32PF5320 32 in. HD-Ready LCD...
My 37" LCD Philips TV has mind on its own.
your internal controller board is going bad in lcd
Jan 19, 2009 | Philips 32PF7320A 32 in. LCD Television
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips 32PF7320A black screen
If the power lamp is flashing 5 times when it does this, you may need a new power supply. Otherwise, I would suspect a bad (solder) connection in the power supply.
Jan 14, 2007 | Philips 32PF7320A 32 in. LCD Television
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
