Washer squeals in rinse or spin
Washer sqeals when in rinse or spin dry
    Problem Solver:
  • 5 Answers
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Posted on Apr 17, 2009
My stackable washer is sqealing just before spin cycle
Common cause of this problem is The sound at high speed spin due to dry bearing of motor and wash tub. lubricate with high temprature grease.If you are not able to do.contact the mechanic
Mar 02, 2015 | Washing Machines
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
Mazda protege 2000 squealing from serpentine belt area check engine light on
it is the belt it is either to tight or not tight enough
Dec 14, 2012 | 2000 Mazda Protege
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Feb 13, 2010 | Maytag PAV2300 Top Load Washer
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Washing Machines Logo
346 people viewed this question
Top Washing Machines Experts
