Displays 71101 and I can not charge the cassette.
I have a VCR SLV-X66HF sony, its display 71101 and i can not charge the cassette.
  • 476 Answers
SOURCE: My Sony SLV-D500P DVD/VCR ejects my tapes.
Hello, I see that you have received an answer to your post. You might want to take a quick look at the load belt located to the right of the cassette mechanism, sometimes this belt becomes loose due to wear and tear and slips on the motor pulley. Another problem that is common is a set of gears located in the middle of the mechanism(drive clutch assembly) this assembly also begins to loosen due to wear and it does not move the reels(pick up and supply) thus pulling the tape out of the cassette housing and triggering the movement detectors inside the mechanism. Replacing the belt seems to be the best option, the clutch assembly requires a bit more skill but if you are not sure there should be a qualified tech in your area that could help you with that. Hope I was able to help.
Posted on Nov 17, 2010
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
  • 309 Answers
SOURCE: DVD freezes when playing on a Sony SLV D300P DVD/VCR
That particular unit is very sensitive to scratched or dirty disks. Remove the disk and make sure there are no finger prints, peanut butter & jelly, or popcorn butter stains on the back side. If there is, gently wash the disk under warm water with a DROP of mild dish detergent, being careful not to scratch the surface. Rinse the disk well and dry with a soft, lint free cloth (like an old cotton t-shirt) again being careful to avoid scratching the disk. Replace the disk and play.
If the disk is scratched, there is little hope of fixing the scratch so the unit can read it.....
Posted on Nov 20, 2009
  • 71 Answers
SOURCE: sony slv-d370p displays dvd_errlog5 message
You`ll find the error codes in the service manual, But I don`t think this will help you, it sounds like you have a compatability problem. Are you not better connecting your turntable up to your PC?? You can purchase these really cheaply out of ASDA and other good retailers now which will plug directly into the USB port. You`ll have no problems then, I promise, I`ve done it. Ian
Has it actually wrote to the disc and have you finalized the disc?? Does the disc look like it`s been wrote to, you can usually see the recorded section of the disc but if it`s not been finalized, It`ll never play on a normal CD player. A CD player requires the TOC (Table Of Contents) in the centre of the disc, if this is missing, the CD will just give up and say disc error or something similar. Ian
hope this helps,thank you
Posted on Feb 10, 2011
muntejaya
  • 10421 Answers
SOURCE: Hi! SONY DVD/VCR SLV-D271P player.
Hello, Please get the code here : www.dvdoverseas.com/dvd.htm
www.regionfreedvd.net/
Regards, Jay__Ujh67g
Posted on Feb 25, 2011
My Sony VCR will not accept a tape and displays 71101 as the error code.
Hi John, I searched under "error code 71101 sony VCR" you'll get quite a few hits including fixya but there are several others which could be worth a look.
Mar 05, 2015 | Sony Televison & Video
My Sony VCR Model SLV-662HF will not accept cassettes. I am using a universal remote control. The VCR's display shows APC 71501 and 81508. Do these APC codes refer to the VCR or the All In One universal...
The codes are to program the universal remote control to communicate with the Sony VCR. Try programming the universal remote using one of these: 60000 60032 60033 60035
The acceptance of the cassettes may not be related to the use of a universal remote control. If the URC doesn't have the "equivalent" functionality of the VCR's original remote control, you may not be able to use the URC to perform the functions of the original remote control.
Dec 13, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
I need the video head for a sony slv 815
The parts you are looking won't be easy to find, go online to sony, contact customer support, and the technical department to see if they can help, if not! try and find a repairman that still repairs vcr's, because he would have access to part suppliers that may still carry what you need.
Apr 21, 2012 | Sony SLV-N81 SLV-N81 Video Cassette...
How do u get off apc on the display from a sony slv-n71 vcr
Press MENU on the remote for the Sony VCR. Go into the ADVANCED OPTIONS. Next scroll down to the line that says NEXT for next page because its on the second page of advanced options. Press enter or execute to see the second page. On this second page look for APC (adaptive picture control) and you can set it ON or OFF. Set to OFF to remove APC from the front panel display. Note: it is recommended to have APC set to ON.
Aug 30, 2010 | Sony SLV-N71 VCR
Cassette jammed, system cutting out.
Take cover off and turn the loading motor until it come out.
May 24, 2010 | Sony SLV-SE730 VHS VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
Sony SLV-D370P DVD Player / VCR Combo I get the following error -This disc cannot be played. Please check the desk DVD_ERRLOG5 00050106000000000006 01010c00000300020024 Any suggestions....
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Jul 03, 2009 | Sony SLV-D370P DVD Player/VCR
Sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Jun 25, 2009 | Sony SLV-675HF VCR
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Televison & Video Logo
337 people viewed this question
Top Televison & Video Experts
Electro Med Services...
