Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Chainsaw diesels, and won't shut off unless choked.
Chainsaw won't shut off with ignition ground switch when hot. Have to choke it to stop it. What's with this dieseling? Thanks.
    Brigadier General:
  • 4,088 Answers
Hot carbon deposits in the head and spark plug are usual dieseling culprits. If this saw has a long history with heavy oil/gas ratio, it will probably build these deposits. Pull the spark plug, and check for proper color which should be light to darker tan. Is the plug the proper one for this engine? Also, you should check the high-speed setting on the carburetor--(engine warm). High speed unloaded--should 4-stroke and with light-load (cutting wood) smooth out and fire evenly. Too-lean (CW) gives high revs and lots of heat. Hope that helps.
Posted on Jul 05, 2009
  • 33 Answers
Sounds like its a littel out of time
Posted on May 05, 2009
I HAVE A KAWASAKI 19 HP 601V and it starts and runs great but if i stop it hot, it takes forever to get it restarted. choke, no choke, no matter. plugs are dry. there is fuel in sediment bowl when I open...
The fuel shut off valve is a solinoid that pushes a pin into the bottom of the main jet shutting the fuel flow down when the engine is switched off, this is to stop un burnt fuel entering the hot exhaust causing loud bangs as the fuel ignites, if you remove the valve, switch the ignition on, the pin should retractfully into it housing.
Aug 25, 2013 | Garden
I have a Ryobi 780r that won't run unless it is on choke. The moment I remove the switch from choke to run it shuts off.
This means you have an air leak somewhere adding more air than fuel with the choke off. With the choke on it blocks off the fresh air coming in and mixes with the maverick air from the air leak. You need to find the leak and fix it or you may damage the unit
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 10, 2013 | Ryobi Garden
Having trouble shutting off Stihl chainsaw
the kill switch wire might have broke between the coil and the switch
May 19, 2012 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Finally started my 79 suzuki TS 250 and it wouldn`t stop. There`s no kill switch. I had to turn off the fuel and let it run out. Kind of worried about starting again. Tried starting it again, but having...
To stop a dieseling two stroke motor you can either choke them out (full choke) or block the air intake with a rag and starve the motor for air. Chances are the carburetor slide is sticking in a wide open position. Take the carburetor apart clean and inspect it. Also inspect the intake manifold for cracks and air leaks. For normal running add a kill switch so you can stop the motor without having to unplug or ground the spark plug. If the motorcycle is completely stripped except for a power wire to the coil, add the kill switch between the generator (wire coming out of the motor) and the coil.
May 09, 2011 | 1971 Suzuki T 350
Chainsaw will not shut off using stop, I have to use the choke to shut it off. Husqvarna 455 Rancher
the wire on the stop switch probably came of the terminal. take the top cover off 3 screws ,and the air cleaner. you just replug it.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Stihl MS250C Chainsaw works great won't turn off!
That wire should go to the kill switch. IT just grounds out the magento. See the on off switch, and put it back on there.
Jul 23, 2010 | Stihl Chainsaw Throttle Trigger 012 O12...
M842 chainsaw wont start when hot
I suspect your warm start procedure is the fault, the manual is not correct IMO. Any choke on a warm engine causes flooding, try this, if no better post back or return it for warranty replacement.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | McCulloch Garden
Stop button not working
A stop button is just an on off switch or a monitary off(Short) switch which shorts out the primary to the coil. Either the switch is broken , the ground wire not making good ground or the primary wire to the switch is off. You can get any two position switch, (for example from radio shack) and replace it withhe noew on if the switch itself. Trace the two wires to see if they are connected. Most likely is the ground one is off or disconnected.
Feb 27, 2009 | Husqvarna Garden
Will not start on hot day's in the sun.[engine cranks normal]
The normal reason why a hot engine doesn't start is the choke. Your fancy new range rover will have a computer controlled choke that will be activiated by a temperature sensor. maybe this has failed or is disconnected
In my ancient range rover I have a manual choke but essentially the same engine. I know that if the motor is hot I can't start it with the choke on.
The way the choke works is it restricts the airflow into the engine so that there is a richer fuel / air mixture which is needed for a cold start. If the engine is hot and the choke comes on the engiine floods with petrol and there isn't enough oxygen for it too ignite in the cylinders. To start a flooded engine you have to open the choke and crank the motor without pressing the accelerator. This pumps out the petrol vapour and eventually it will fire and start. If the computer thinks it is cold because of a disconnected or faulty sensor it will put on the choke whenever you try and start and the engine will flood.
I think a vapour lock is unlikely unless you driving in extremely hot weather (above 40 degrees celsius).
Oct 08, 2008 | 2008 Land Rover Range Rover
Carb choke
yes ground and hot
youur hot wire needs to hook into ignition circuit so it is hot with key on
Sep 05, 2008 | 1966 Ford Mustang
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
213 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
