Printer keep saying print cartridge cradel is stuck and clear jam, but there is no jam.
It keep saying print cradle stuck, clear jam, but there is no jam
  • 523 Answers
Check the sensor , either there is somthing stucking on the sensor you cannot see it, either the sensor it self becomes bad.
Posted on Apr 17, 2009
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
HP PSC 1500 series print cartidge cradel cannot move?
Does is look/sound like the cradle is attempting to move? Make a loud popping sound? There is small belt that is used to guide cradle across the platen. Take a closer look to see if anything is obstructing that belt. It's rubber and looks like it has gear teeth on it and fits around white gear wheels on side of cradle.
If it doesnt' move at all, a hard reset might clear it. You'll have contact HP support for that as each printer model is different. Some you just hold the power button in for a certain number of seconds.
A soft reset can be tried by unplugging power cord from printer and waiting 15 seconds then reattach power.
Oct 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
I reconnected my printer and it says..''Print cartridge cradle is stuck. Clear jam and then press OK''. What do I do? Where's the cradle? I'm messing with it and I got nothing. I HAVE to print out...
>the cradle is the carriage which hold your print cartridge.
>follow the steps on this link, this should resolve your issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255616&cc=us&lc=en&dlc=en&product=397810
Sep 29, 2009 | HP Photosmart 8150 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
There is a print cartridge crudle is stuck...clear jam and press ok saying on the screen of my printer what should i do?i cleared the paper jam but it still says the same thing
Remove your cartridges, pull the power out see if the cradle moves freely around by hand. Check make sure that theres no paper that stayed behind. Did you rmove the paper by force? Maybe you dmaged the paper sensor.
Dec 08, 2008 | HP Photosmart 8150 InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
368 people viewed this question
k24674
jasbo
jasbo
