Question about Ovens
My wife has cancer and had a brain operation. She fell down on the kitchen floor and on the way down she grabbed the handle of the oven and now I cannot get the door on all the way or connot get closed. Can yo please tell me what to do. I now have the frame loose around the glass.
  • 116 Answers
Slide the door all the on the pins. they are spring loaded so be careful. there is a groove for it good luck.
Posted on Apr 17, 2009
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
I was cleaning inner glass on oven door & it fell out . how do i fix it pls
Tecnik was a brand used by Moben kitchens who went bust so Tecnik are a non brand now. You may find a kitchen appliance engineer who would pop in and assist but don't hold your breath if it fails later. As a result there are no handbooks to download. Sorry.
Jul 21, 2014 | Tecnik TKC201/3 Electric Single Oven
Door handle fell off of oven
Rachel, every range oven door I've seen, that was built in the last 20 years comes off the range by opening it about 6 - 8 in. from the top of the door frame, taking a firm grip on both sides about 8 - 10 in. down, bend the knees slightly, get a good grip on the door and pull up sharply. The door should release from the spring hinge on each side. Once you have it out you can lay it flat on the kitchen table, (preferably on a towel or cloth of some sort), with the inside facing up. There should be several screws that hold the interior portion of the door to the outer portion. If you remove these screws you should be able to remove the inner portion of the door, by pulling straight up, easily, and put it on the floor or if there's room, on the counter or table. Now you should be able to locate the holes the screws go into, to hold the handle on the door. If they connect from the interior, you should have found them when the interior was off the first time. Take them and install the handle. If there are none, find some chatterproof washers and put one on the inner side of each screw to keep them from loosening again. Once you have the handle secured to the door you should be able to put it back together. After you have assembled the two halves of the oven door, make sure the two hinge assemblies are pulled away from the frame of the oven at approx. a 35 degree angle. This is necessary to have the proper clearance to allow the door to slide down onto the hinges and grab on inside. The door should slide right down over the two hinges and then you can close it up.
Mar 05, 2014 | Whirlpool Ovens
The handle on the bottom oven fell off. how do i reattach it?
I suppose the handle you are talking about, is the long, wide one, used to pull that oven door open, right? I personally do not have any experience with this particular oven-- However:
These handles are usually held on by a long screw at each end.
So-- when you look at the handle-- do you see where the screws should attach at each end?
And do you see matching holes thru the door-- where the handle was once attached?
Now: Where are the screws?
We know they were there at one time, right?
So-- can you open the door, and can you locate where the screws are now?
Once you locate the screws, can you hold the handle, and re- screw the screws ito the threads in the handle? You have the necessary tools? -- Screw driver and flash light?
When you examine things closely-- get back with us, and we can help you to your next step.
Mack B
Jan 15, 2011 | Electrolux ICON 30 in. Double Wall Oven
My oven door handle fell off
remove the screws and the door will seperate and you can reinstall the door handle.. mm most whirl ovens have lift off doors this may make it easy to work on .. mm hope this helps if more help is needed i need your model # off the tag on your oven .. mm feed back pls .
Nov 25, 2010 | Whirlpool Ovens
H4080bm Miele microwave handle fell off
Hi Try not to open door with handle as this may cause to glass to smash. When you open the door you will see two pin sticking forward near the top of the door just further back on the top of the door is two small barbs push down on these barbs located in line but further back from the pins.This will release the top of the outer door.The bottom of the glass is hooked into the hinge. with the top released lift door glass away.You should find screw in inner door refit screw with some loctite.
Aug 23, 2010 | Miele H4080BMSS Oven
Hi their i am replacing my old fan oven element. but when i pulled out the old element the wires fell down the back!!! any ideas on how to retreive them? thx
use a coat hanger as a hook to grab then but unplug the stove before you do it. You should be able to sang them without to much difficulty.
Apr 18, 2010 | Whirlpool GMC275PD Electric Double Oven
Replace oven light
If the metal sleeve that the bulb screws into is damaged, you can go to a local appliance repair shop for a replacement. Be sure to unplug the stove before doing any work on it. you will need the make and model of your oven to make sure you get the right part.
In the future, if the bulb detachs from the base on any light you have, 1) disconnect the power, 2) using a small wooden dowel or the plastic handle of a screwdriver that will fit inside the base, apply enough pressure while turning to remove the base. Good Luck.
Aug 06, 2009 | Ovens
Glass oven door fell off
There is probably a retaining bracket behind cooker front panel you will probably have to remove a side panel to access the retaining bracket.
Please rate my solution.
Thanks.
Jul 16, 2009 | Ovens
Door glass shattered 3 hours after cooking
The problem is with the glass. They apparently did not use a strong enough tempered glass during manaufacture. I would call the company and tell them what has happened. They should replace it. It must have been a design flaw or something else. They should make it good. They may want to make a recall.
Feb 25, 2009 | Ovens
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
