Question about Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 Convergence issue
I am not very practiced in fixing tv's, but our 49" Zenith is not converging right and I am in dire need to fix it right now 'cause a repair man just isnt fitting in the budget. When I turn the tv on it gives the effect that the image is being sucked into the center and all three lenses are off of alignment. you can see the 3 distinctive lense colors. I tried auto converge on it and it made it worse. I know it has to be the convergence chips my question is how can I eliminate certain ones as the problem, or basically how do i know which one is the culprit. I have the back off the tv and now I need to know where to go from here. Please help me ASAP
  • Zenith Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including SonyZenith R49W36 Convergence issue - 2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix hereZenith R49W36 Convergence issue - bb0cf99.pngsrc="http://i.fixya.net/uploads/images/bb0cf99.png" alt="bb0cf99.png" class="h_mi" />http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 14, 2010
On my Zenith R49W36 he board where the convergence chips are is burnt and I need to replace - where can I get a new board?
that part is discontinued and no longer available the part number is 6871VSMA97E you may be able to find a used one.
Oct 29, 2011 | Zenith R49W36 49" Rear Projection HDTV
Zenith pvr5263rk can not converge any colors through menu
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 23, 2010 | Zenith R49W36 49" Rear Projection HDTV
I need to know the parameter for configuration for a zenith tv 52 inches R49W36 ,because the colors and image are really bad thanks fredy
Sounds like a convergence problem. I had the same issue. I got a repair kit from the folks at TvRepairKits.com. Worked great for me and saved a ton of money.
Dec 31, 2009 | Zenith R49W36 49" Rear Projection HDTV
My zenith projection tv model R49W36 wont aline the colors green,red and blue
Its a convergence problem. You can get complete parts and instructiosn for this fix from www.TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Dec 22, 2009 | Zenith R49W36 49" Rear Projection HDTV
Zenith 49 in double vision and curved picture
You need to get all of the convergence parts for your TV. Chips, resistors, etc. You can get them from multiple sources over the internet or you can just get a complete kit from www.TvRepairKits.com
Jul 30, 2009 | Zenith R49W36 49" Rear Projection HDTV
Double VIsion on Zenith R49W36
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49w36 problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com The kit had all the parts and simple step by step photos of the repair. At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. You guys rock!
Louis
May 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
My TV Zenith R49W36
my zenith tv model number r49w36 will come on with sound but no picture can someone please help
Apr 17, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 49" Rear Projection HDTV Logo
612 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
