Question about GE Monogram ZDI15C Automatic Icemaker
Ge monogram zd115c automatic icemaker not making ice
My ge monogram zdll5c automatic icemaker is not making ice. The motor is running.GE Monogram stand alone ice maker ZDIS15CSSK runs continuously and loudly, on ON, OFF, and CLEAN settings. Water is running constantly into and out of the appliance. Not sure new ice is being made. Refrigeration is turning on and off ok. Finally had to unplug both plugs to get it to stop. Any ideas?
    President:
  • 1,197 Answers
Investigate each of these two areas if your icemaker is not making ice :
Water Inlet Valve andDefrost Thermostat
now we ll check to see if water inlet valve has a problem
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
directions for testing the water inlet valve is given in the below link
http://www.partselect.com/refrigerator+test-water-valve+repair.htm
directions as to how to replace it is given in the following link
http://www.partselect.com/refrigerator+replace-water-valve+repair.htm
if u need to replace it check out the following link
http://www.partselect.com/locate-parts.aspx?Appliance=Refrigerator&ModelNum=&Type=Valve,%20Water%20Inlet%20-%20Drain%20-%20Backflow
now we ll see to check if the defrost thermostat is the culprit
 It could just be that your freezer thermostat is not set low enough. Try adjusting the thermostat to a colder setting.
Or your icemaker might not be making ice because of a defective defrost thermostat. Test your defrost thermostat to determine if it has malfunctioned. If it has, you will need to replace it.
to test the thermostat follow the below link
http://www.partselect.com/refrigerator+test-defrost-thermostat+repair.htm
to replace it if necessary... clik below link
http://www.partselect.com/refrigerator+replace-defrost-thermostat+repair.htm
for replacement parts kindly check the following link
http://www.partselect.com/locate-parts.aspx?Appliance=Refrigerator&ModelNum=&Type=Thermostat%20-%20Humidistat%20-%20Sensor&MinSize=1&MaxSize=2
thank you
hope i was helpful
good luck with ur ice maker
have a nice day
Posted on Apr 17, 2009
Ge monogram icemaker ZDIW50YB not cutting ice
Is the cutting grid getting warm if just warm make sure you don't have any loose wires supplying power to grid. Check grid cutting transformer to make sure it is working. make sure grid is clean. If you are getting power to cutting grid and it's not getting warm then cube let cutter grid is bad. If this needs to be replaced you might thank about a new machine the cost for this part is around 480.00 part number AP2068335
Aug 22, 2014 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Ice Maker
Could you please describe the problem you are having a little better?
Nov 21, 2012 | GE Monogram ZDI15C Automatic Icemaker
Bad humming noise for ge monogram ice maker zdis150wss. stopped working entirely.
pretty big job to replace compressor on this refrigerator. Thats video I made on one of my customers monogram. Hope That helps.
Apr 20, 2011 | GE Monogram ZDI15C Automatic Icemaker
Monogram stand alone Ice machine continually drops ice when full
The thermistor can cause the ice-maker to run at all the time and harvest the ice slab. Replace the thermistor with this part.
Jan 27, 2011 | GE Monogram ZDI15C Automatic Icemaker
Very Hot compressor on Ice machine model ZDIS15CBSS
It's probally the condenser fan motor. Is it running during icemaking? To replace this motor you have to take the two screws out of the front of the icemake at the front adjustment screws and then tilt the
Jul 15, 2010 | GE Monogram ZDI15C Automatic Icemaker
Manually add water?
Put 2 cups of water into the maker.
Jun 20, 2010 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 27, 2009 | GE Monogram ZDI15C Automatic Icemaker
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Nov 04, 2007 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15C Automatic Icemaker Logo
227 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
